10-10-2013, 08:27 PM | #1 |
Newbie Join Date: Apr 2013 Location: So Cal
| metal spur/pinion gears
I installed the Robinson metal spur gear and pinion and set the mesh and getting small shavings when I first started running it, just checking if that's normal
10-10-2013, 08:36 PM | #2 |
Quarry Creeper Join Date: Oct 2011 Location: New Mexico
| Re: metal spur/pinion gears
I have a metal 72 tooth spur for/from my emaxx. Honestly i wouldnt run it and I would happily give it away to someone who asked for it. All it ever did was eat pinions. I got it for free with a bunch of old parts. It will fit my wraith with my extended outputs but i still wouldnt run it. When people talk about getting a metal spur, in the back of my mind i cant understand how people run them without issue.
10-10-2013, 08:51 PM | #3 | |
Rock Crawler Join Date: Aug 2010 Location: Saint Marys, OH
| Re: metal spur/pinion gears Quote:
On a standard pinion, you more than likely are tearing off the plating that was on the pinion, it will fail at some point. When using a steel spur, you should also use a hardened steel pinion for longevity, such as one from RRP's Absolute line. There are other manufacturers that make hardened steel pinions so do a little shopping around. | |
10-10-2013, 09:05 PM | #4 |
I am runing the Robinson 1714 absolute hardened one
metal spur/pinion gears - Similar Threads | ||||
Pinion and spur gears | mltxj9889 | Axial SCX-10 | 1 | 04-26-2011 11:14 PM |
metal pinion/plastic spur??? | jpax10 | Newbie General | 3 | 05-01-2010 08:01 AM |
Questions about spur gears and pinion gears... | Chadworkz | General Crawlers | 6 | 12-03-2008 02:04 PM |
metal spur gears | TJ_Shunk | Tamiya TLT Crawlers | 9 | 11-07-2006 12:37 PM |
