10-19-2013, 06:07 PM | #1 |
Quarry Creeper Join Date: Aug 2013 Location: South Crawlolina
| Wraith is locking up?
My wraith was going up a small hill, not steep at all, and as soon i let off the throttle it stopped so hard that the truck leaned forward. I thought 'hmmmmm weird' so i drove off again. When i hit the throttle the opposite happened, it leaned back. I thought 'slipper must be off' then it slowed down rapidly but didn't stop. I tried to take off then heard metal clanking and the truck wouldn't move. I walked up to it and noticed that the pinion was on the ground. So i cut off and try to push it down the hill and it doesn't move. Usually my cars roll down the hill about 10 feet and then stop. its much easier than carrying them and i'm lazy so... I took apart the trans. and their are the gears in perfect shape , no stripping. I re adjust the slipper and still its locked up. while the trans was out i rolled the axles around and it was fine. i took the motor out of the trans and still no movement. put it back together and ran it for 5 min. It was significantly slower and the motor temp was HOT!!! I know the batt is not dead but i cant figure it out. it is driving me craZy. |
10-19-2013, 06:52 PM | #2 |
Rock Stacker Join Date: Dec 2009 Location: New Hampshire
Only thing you haven't checked is the esc. But not sure why that would effect it while it was off, but worth checking I suppose.
10-19-2013, 07:14 PM | #3 |
Pebble Pounder Join Date: Apr 2013 Location: Thibodaux, LA
| Re: Wraith is locking up?
Check the drive line angle. Check the electrical connections on the motor. I've had this happen before and those were my issues. Good luck
10-19-2013, 07:42 PM | #4 |
Rock Crawler Join Date: Jul 2009 Location: Victoria Australia
Have you checked the bearing's in the trans.
10-19-2013, 07:55 PM | #5 |
I wanna be Dave Join Date: Dec 2006 Location: Goin broke losing weight.....
Does everything run smooth without the motor installed? Can you turn motor shaft easily by hand?
10-19-2013, 09:03 PM | #6 |
| Re: Wraith is locking up? No, it's the same story without the motor. Bearings I have not checked. +1 to you, greenjk.
Last edited by lostonthetrails; 10-19-2013 at 09:06 PM. Reason: Forgot to multi-quote |
10-19-2013, 09:22 PM | #7 |
Pebble Pounder Join Date: Apr 2012 Location: springfield
I had a similar issue and it was my drive shafts were to steep
10-19-2013, 10:28 PM | #8 |
Well figured out it was that my slipper had dug itself into the motor plate an ceased the trans. It also destroyed the slipper pad. I see all my money spinning round and round down the toilet.
10-20-2013, 08:23 AM | #9 | |
RCC Addict Join Date: Mar 2013 Location: Oklahoma City
| Re: Wraith is locking up? Quote:
...Perhaps less lazy and more attention to post run maintenance.... | |
10-20-2013, 06:27 PM | #10 |
RCC Addict Join Date: May 2008 Location: Southern,WV
| Re: Wraith is locking up? I think just making your point about post run maintenance would have been enough...Unless you were trying to be an asshole with the lazy comment....And If that's the case..You achieved your goal.... |
10-20-2013, 07:24 PM | #11 |
Ill leave it to him to decide. Feel free to brush up on your reading comprehension skills prior to posting cowardice remarks. I suspect I struck a nerve in you with the lazy comment since it incited such backlash...hehehe, but I'll sleep well tonight just the same. Last edited by redsawacs; 10-21-2013 at 12:50 AM. |
10-21-2013, 11:27 AM | #12 | |
who are you talking like that Yoda?LOL Maybe something like Perhaps you should focus more on post run maintenance so things like this don't happen. There that sounds better.As as far as your cowardice and lazy comments aimed toward me.....lol I worked 3 job right out of high school and into collage and for extra cash I fought as a mma fighter for 12 years until I became disabled.So there's no cowardice or laziness here. Only a guy who hates to see other people being put down.Sorry if I offended you but it just gets me when people attack without cause. So I too will sleep well knowing that at least one person has been showed the error of there bullying ways. | |
10-21-2013, 04:17 PM | #13 |
Pebble Pounder Join Date: Apr 2012 Location: Canada
Check the bearing on the top shaft I've had a few seize and it acted the way you described Sent from my SGH-I337M using Tapatalk 2 |
10-24-2013, 07:42 PM | #14 |
Newbie Join Date: Jun 2013 Location: Springfield
what would it mean if the connection from your motor got hot and black causing the cut out (just the white one)?
Wraith is locking up? - Similar Threads | ||||
Why locking the differentials? | kc092755 | Newbie General | 7 | 08-30-2009 10:46 AM |
help locking diff | macruz | General Crawlers | 7 | 09-06-2008 12:25 AM |
Locking diffs | Norcal crawler | Newbie General | 10 | 01-09-2007 06:18 PM |
Locking the diffs | kailuaboy | Tamiya Txt-1 and Juggernaut | 8 | 01-02-2007 03:09 PM |
locking the diffs | staffbull | General Crawlers | 3 | 11-13-2006 06:05 PM |
