Thread: A Wroncho Lovers 1.9 Wraith build!
Old 10-22-2013, 09:20 AM   #1
Default A Wroncho Lovers 1.9 Wraith build! AKA The MINI Wraith
After going from every scx10 posibility, finally settling on my wroncho (see build thread: My ever-evolving SCX10) I decided to buy a wraith and put scx10 axles under it.
Here is the start up;
Bought a used wraith that had a BRXL, holmes 13t motor, front battery mod, assorted other junk with it. Sold the axles off, got some scx10 axles and a DMG front truss, threw them under the wraith, which was pretty easy! Suspension is still mocked up with 100mm shocks. Installed some Axial HD gears normal front , under drive rear. Got some 1.9 pitbulls with CI foams on 1.9 axial wheels 3.5oz up front 2.5 in the rear. I already had a hitec 5995tg lying around. Off to a good cheap start after buying, selling, and using stuff I've had sitting in boxes.
I've got a big order on the way;
Aluminum knuckles
Blue Monkey titanium steering
93mm XD shocks
Vanquish CMS
MIP shafts
and alot of stuff I can't remember haha
On to the pictures, which will have a simple layout of how it sits now.
Axles thrown under. Slash tires for mock up. Wheelbase needed shortened.
So right above is where it site before the next order.
Wraith Chasiss (fastback)
SCX10 axles with HD gears, alum chubs, and hot racing lockers
Front DMG panhard truss
Vanquish panhard mount
(I think) Hot racing trans gears.
100mm shocks (too long)
1.9 pitbulls
front wheelbase is perfect.
Front battery (5000mah 3s hardcase)
BRXL ESC on top of transmission
Castle BEC
No come will be:
Vanquish CMS with hitec 5995tg
Aluminum knuckles
Blue Monkey titanium steering links
MIP CVD drive shafts
Gmade 93mm XD shocks
Shorter wheelbase in rear.
ProjectSCX10 is offline   Reply With Quote
Old 10-22-2013, 06:51 PM   #2
Default Re: A Wroncho Lovers 1.9 Wraith build!
Wow that looks beast! I've been debating on doing this with my Wraith! I have the aluminum links for the Wraith wheelbase (Axial) so my question is, will the wheelbase look the same as yours with the 1.9 axles?
Also all you need for that is the scx10 axles? Do you need the scx10 tranny as well or no? Along with that if the answer is we can use the Wraith tranny can we also use the MIPs for the Wraith tranny?
Thanks for your time in advance!
NewbieRC361 is offline   Reply With Quote
Old 10-23-2013, 06:47 PM   #3
Use the shorter plastic rod ends that come with the wraith kit, thats what I did, And you'll need shorter upper links as well. Then yes the stock wraith trans will work, and I'm using ax10 MIP shafts which are shorter since I shortened the wheelbase up.
Wait until you see some new pix from my build today.
Old 10-24-2013, 03:59 PM   #4
Natedog's Avatar
Aluminum knuckles
93mm XD shocks
Vanquish CMS
MIP shafts
1.9 pitbulls
Castle BEC
No come will be:
Aluminum knuckles
Looking good so far, love my Wraith, but love the 1.9 builds too! I'd run a smaller battery for better side hilling, I get 30 to 40 minutes with 1350mah 3s lipo and Titan 21T geared 13/56 (with 2.2 Ripsaws) and it still crawls great. Shorter rear links should do it. What's your wheelbase goal?
Old 01-02-2014, 10:32 AM   #5
Oh boy have I made some changes.... I forgot I started this thread..... I'll list it out again with pictures.
100mm King shocks with 70wt oil.
Dinky Cheap seats
MIPs
RC4WD HD XVD front CVDs
Wheelbase is at 12.6
Traxxas 21t Titan motor geared at 16/87
Soft front/Medium Rear Crawler Innovations Lil'Nova foams
1.9 Pits
HD Bevel gears (normal front, underdrive rear)
Marine grease packed the axles
Minion Driver!
here is a good shot of the wheelbase
Added Angle from the XVD shafts and shaving the knuckle arms a tad
I tried 1.9 Trepadors with the same foams. I hated them. Only terrain I haven't tried them on is straight rock. That is the last test for them.
Size comparison haha
Old 01-02-2014, 09:26 PM   #6
How do you like that Titan motor?
Tgreer is offline   Reply With Quote
Old 01-02-2014, 10:32 PM   #7
That thing is sick, looks awesome!!!
nwcrawler is offline   Reply With Quote
Old 01-07-2014, 07:26 AM   #8
***Didn't realize all the titles were the same. It is 4 differnet videos***
Some videos of me and my brother on Stone Mountain:
Mini Wraith and Dingo on Stone Mountain - YouTube
Old 01-07-2014, 07:28 AM   #9
I actually love it! On 3s it has plenty of wheel speed; crawls as slow as possible; and nothing stops it. I have it geared at 16/87. I got just under 3 hours of run time on a 5000mah pack over the weekend.
If you try it make sure its the 21t, not the 12t. I tried the 12 and its wayyy to fast.
Old 01-08-2014, 01:55 AM   #10
Did you use the stock or reverse direction Titan motor?
Tonysmini is offline   Reply With Quote
Old 01-09-2014, 01:58 PM   #11
Stock direction. So I do have to run it clockwise.....
Didn't know there was a reverse one? I'd love to have one thats reverse!
Old 01-09-2014, 05:52 PM   #12
just switch the power wires to reverse the motor.
I have the wires switched on my BR-XL with my HH 13Ttorquemaster in my wraith
realsickclown is offline   Reply With Quote
Old 01-10-2014, 07:10 AM   #13
Well yeah, I switched my wires lol...... -_-
But the Titan motors have a little bit of CCW timing. So runing them clock wise retards the built in timing making them slower when s[inning clockwise rather than CCW. I did the research and found the reverse model of the Titan 21t. I'll be getting 1 or 2 for spares. I know I can just swap the endbell around, but they are so cheap that its more trouble than its worth to me.....
Old 03-16-2015, 11:12 PM   #14
any updates, love this rig and want to see where its at today
photocycler is offline   Reply With Quote
A Wroncho Lovers 1.9 Wraith build! - Similar Threads
VP`s JK Wroncho build zonkerd Axial SCX-10 58 04-03-2014 08:38 AM
Wroncho build krawlerkid15 2.2 Scale Rigs 2 06-11-2013 09:46 PM
Wraith skid wroncho nuckle 2.2 Scale Rigs 11 03-05-2013 02:35 PM
Wroncho build Problems RcBashertruck Axial SCX-10 22 10-16-2012 09:57 AM
