10-30-2013, 07:13 AM | #1 |
Pebble Pounder Join Date: Sep 2013 Location: Mechanicsburg, PA
| Setup of stock Wraith wheels tires and foam
Look to set up my stock Wraith wheels. I am using the stock wheels, tires and foam for now. These will be glued and I want to get the best all around performance with this setup. There has got to be a happy medium for this so I am thinking a slight star pattern of 8 points on the foam will be ok. I am learning to crawl and just drive around. My Wraith is set up with the following power train. Holmes 13t Crawlmaster Pro & BRXL ESC Castle BEC Pro Geared 32p 56/12 HiTec 7950 Turnigy 2200 mA 3S 45~90C LiPo My Questions: Will an 8 point star on the stock foam be ok for light crawling and driving around? Will this be to soft of a wheel configuration on the stock setup? Thanks |
10-30-2013, 04:14 PM | #2 |
RCC Addict Join Date: Mar 2013 Location: Oklahoma City
| Re: Setup of stock Wraith wheels tires and foam
Tire compound is just as important as your foams. If you are running the stock RTR tires, I would recommend that you purchase the R35 whitedot tires and use them with the stock foams if you dont want to buy other foams. I am running R35 ripsaws with stock foams on VERY vented wheels and I like it. Not perfect, wish I had money for real tires and foams.....but I dont. SOrry I couldnt answer your question about cutting foam, just keep in mind, you're limiting yourself with a good compound tire. |
10-30-2013, 04:19 PM | #3 |
I wanna be Dave Join Date: May 2011 Location: Lost in Oregon
the weight of the rig has a lot to do with the foam set up also...
10-30-2013, 04:55 PM | #4 | ||
| Re: Setup of stock Wraith wheels tires and foam Quote:
I have the Axial Wraith kit and it comes with the Quote:
I am also running the stock wheel. I am looking at getting the Hot Racing multi-width hex adapters fit kit to widen the front so I can run the RcBbros knuckle weights. | ||
10-30-2013, 05:06 PM | #5 |
| Re: Setup of stock Wraith wheels tires and foam |
10-30-2013, 05:07 PM | #6 |
Don't make the foams softer than they already are. They need more sidewall support than stock.
10-30-2013, 05:13 PM | #7 |
10-30-2013, 05:40 PM | #8 |
Quarry Creeper Join Date: Jun 2013 Location: Tacoma
I did a gear pattern cut on my foams for my super swampers. I dont have any issues with it and it grips very well on my climbs. I am considering some uncut double deuce foams from Crawler Innovations to use in place of the ProLine foams.
10-30-2013, 07:33 PM | #9 | |
The heavier the rig the stiffer the foams...you got to play with it a bit, there is no cut and dried recommendation | |
10-31-2013, 01:38 AM | #10 |
There is a few write-ups in the tires/wheels thread at the top of the forums page. In theses you will find tire/foam set ups from people who test against stock setups and tell you what they think. I suggest you look a r them before you decide to throw away your money. Remember, don't buy something simply because a few people say, "I use them and the are fantastic!".....compared to what!?!? |
10-31-2013, 08:36 AM | #11 |
Quarry Creeper Join Date: Jan 2013 Location: Julian, CA
The R35 Ripsaws are TONS better than the RTR. A buddy and I went head to head. So thast's a first hand opinion right there. Cutting them, every other nub or so, makes a huge difference. Shaved them too. On both the R35 and RTR. My buddy cut his foams. Helped a bit. We strickly crawl. The slower the better. I have found soft and heavy allows me to climb almost anything. I am now running Sedonas with Crawler Innovations foams on XR10 wheels, weighted to the gills. Last edited by Bansh88; 10-31-2013 at 08:53 AM. |
Setup of stock Wraith wheels tires and foam - Similar Threads | ||||
Wraith stock tires inlclude foam? | Madkiki | Newbie General | 2 | 09-01-2012 05:12 PM |
Stock tires, foam or no foam... | warfish | Losi Micro-Rock Crawler | 8 | 04-15-2011 12:33 PM |
do i trim the memory foam like i did the reg foam with the stock tires? | bmuenter | Tires and Wheels | 8 | 08-15-2008 08:59 PM |
