10-30-2013, 07:59 AM | #1 |
Quarry Creeper Join Date: Nov 2012 Location: Paxton
| need help finding set screws
dumb question I know, but I need some screws that hold the ball end of my MIP to the output of my AX2 transmission. I have found 2 different one on RPP but i'm not sure which size I need Traxxas Screw Pin 4x15mm Revo (6) Axial Wraith Screw Shaft M3x2.5x11mm (10pcs I want to assume that its the axial stuff, but I want to be sure before I order. |
10-30-2013, 08:57 AM | #2 |
| Re: need help finding set screws
It depends on which MIP shafts you are using. If you are using #11116 / Wraith then you use the stock Axial cross pins. If you are using #08101 (AX10) then you use the Traxxas Screw Pin 4x15mm #5145 |
10-30-2013, 04:49 PM | #3 |
I guess I need the axial stuff like I thought.
10-31-2013, 08:32 AM | #4 |
Quarry Creeper Join Date: Jan 2013 Location: Julian, CA
If you have a specialty nut/bolt store in your area. Go there and get them for a fraction of the cost. Out here in San Diego, we have Ababa Bolt. I took in the measurements for a couple axial sizes. Walked out with 2 bags of 100 for what a few would have cost from Amain. Often have the choice for Stainless too.
10-31-2013, 08:35 AM | #5 |
2013 2.2P Nat. Champion Join Date: Sep 2009 Location: BorderLine Crawlers Season 3 is on!
| Re: need help finding set screws |
10-31-2013, 03:55 PM | #6 |
I get all my hardware from a vendor that comes to where I work. but I just ordered a bag of 10 on ebay for $5 shipped. that should be more than enough for me for awhile, since I only need one.
need help finding set screws - Similar Threads | ||||
set screws!!!!!! ahhhh!!!!! help please... | desertmaxx | Chit Chat | 17 | 02-23-2013 03:30 AM |
Set screws | Krazykayak | Venom Creeper | 7 | 06-30-2010 01:12 AM |
Driveshaft set screws... | artsifrtsi | Team Losi Comp Crawler | 4 | 02-17-2010 11:12 AM |
Set screws | losikid | Team Losi Comp Crawler | 12 | 08-17-2009 08:39 PM |
set screws? | resetpunk | Newbie General | 9 | 06-16-2008 02:13 PM |
