11-04-2013, 11:04 AM | #1 |
Newbie Join Date: Nov 2009 Location: BALLGROUND
| Wheels problem.
I am working on an axial wraith? It has vp curries on it using axial metal chubs and nuckles on it. What is the bearing size for part number AX30760? I am using 5x11x4 they dont seem to lock in they just fall out. For some reason all four wheels are tight but when you run it all four wheels wobble on the truck. Does any body know what may be causing that? If any one can help that would be great.
11-04-2013, 02:32 PM | #2 |
RCC Addict Join Date: Mar 2013 Location: Oklahoma City
| Re: Wheels problem.
Stock bearings - The inside bearing is larger than the outside - hint hint Manual will tell you what size, if you need new ones, you can reference that. Its possible that the bearings aren't a SUPER tight fit but still the right size. You 're gonna get some movement because the bearings are so close together inside the knuckle. If its too much slop, they may be worn and in need of replacement. 5x11x4 10x15x4 |
11-04-2013, 08:22 PM | #3 |
| Re: Wheels problem.
Thanks. They are new bearing and I have both sizes in the knuckles. I have the smaller one's on outside and the larger one's on inside. The other thing is the outer bearing just falls out. Seems like it is just a little bit bigger then a 5x11x4mm.
11-05-2013, 12:41 PM | #4 |
| Re: Wheels problem.
Its hard to make metal on metal fit without it being too tight or too loose. Call the folks you bought from and ask for a different pair of knuckles and hope they fit better. Yes, I run stock knuckles, they just work for me. |
11-05-2013, 02:40 PM | #5 |
Rock Crawler Join Date: Dec 2011 Location: Blacksburg
| Re: Wheels problem.
Might be the foam in the tires a little off center, that could cause the problem you are having.
Wheels problem. - Similar Threads | ||||
oem 1.9 steel wheels problem | jordan541 | Tires and Wheels | 3 | 12-31-2010 06:39 PM |
DNA 1.9 wheels problem | Laker67 | Tires and Wheels | 3 | 04-18-2009 08:36 PM |
problem wheels turing wrong | homer | Tamiya CR-01 | 7 | 02-23-2009 03:17 PM |
CR-01 problem: wheels not turning smoothly. | PumpkinPie | Tamiya CR-01 | 2 | 01-01-2009 02:14 PM |
Rear wheels slip problem, help! | MonsterDDT | Tamiya CR-01 | 20 | 08-23-2008 05:19 PM |
