Thread: Stock shock spring
Old 12-26-2013, 11:42 AM   #1
Question Stock shock spring
I am planning to buy some springs for my shocks. I am crawling, trail running most of the time. The stock springs are too stout. Not wanting to change shocks yet as I have modded these so they don't leak. So far, so good.
What would be a good soft spring to start at? Should I change the length? I am also going to add a rear sway bar to help with some torqe twist. Thinking of adding a little stiffer spring to help with the torque too. Any ideas?
Thanks for the help guys!
Wacki is offline   Reply With Quote
Old 12-26-2013, 12:38 PM   #2
Default Re: Stock shock spring
Here's a list of the Axial part number, color, & spring rate.
Hope this helps you out. I do beleive the stock springs are
the reds ones at 2.07. hight the number the stiffer the spring
the lower the number the softer the spring.
AX30222 Blue 3.55
AX30221 Yellow 3.27
AX30220 Green 2.85
AX30219 White 2.47
AX30218 Red 2.07
AX30225 Orange 1.75
AX30224 Purple 1.43
AX30223 Black 1.07
I beleive that's all of them.
Baddawg775 is offline   Reply With Quote
Old 12-26-2013, 12:42 PM   #3
Great! THANKS
Old 12-26-2013, 03:25 PM   #4
What mod did you make to stock shocks so they don't leak any more?
prisihayabusa is offline   Reply With Quote
Old 12-26-2013, 09:16 PM   #5
Wink Re: Stock shock spring
I took them apart and used thin teflon tape on the top cap. Used some green slim on the bottom. Tightened very tight. So far so good!
Old 12-26-2013, 09:50 PM   #6
I put losi gold springs on mine they work awesome
nwcrawler is offline   Reply With Quote
Old 12-26-2013, 10:34 PM   #7
What is the part#? Are they pretty soft?
Old 12-26-2013, 10:39 PM   #8
Get the axial black springs....perfect spring
redsawacs is offline   Reply With Quote
Old 12-27-2013, 02:08 AM   #9
I'm thinking of picking up some of the Axial purple for the front & black for the rear.
I figure it can't hurt to have some of each color to fine tune the stock shocks.
Old 12-27-2013, 08:08 AM   #10
I can't remember the part number, but they are soft but still enough stiffness that it's stable
Old 12-27-2013, 08:41 AM   #11
The purples come on the kit wraith and I have never seen a need to change them.
Calderwood is offline   Reply With Quote
Old 12-27-2013, 06:50 PM   #12
With the battery mounted up front this is what i ran and it felt great. Have golds all the way around on it now and doesnt feel as good.
mindless is offline   Reply With Quote
Old 12-28-2013, 01:11 AM   #13
I run purples all around. Im not one to spend hours and hours tuning my suspension, but they work great for me
gottorque is offline   Reply With Quote
Stock shock spring - Similar Threads
New Shock (inner spring) megapro Axial SCX-10 4 08-02-2013 10:09 AM
bj shock n spring help drpuffmd Axial XR10 11 12-30-2011 11:35 AM
Set up tips with stock chassis and shock spring question Interceptor HPI Wheely King 4 09-29-2011 02:01 AM
Shock oil and shock spring help entropy General Crawlers 10 01-29-2011 08:40 AM
Internal spring/ and stock spring set up wassaakk Newbie General 7 06-06-2010 06:53 PM
