12-26-2013, 11:42 AM | #1 |
Pebble Pounder Join Date: Nov 2013 Location: HILLBILLY ACRES
| Stock shock spring
I am planning to buy some springs for my shocks. I am crawling, trail running most of the time. The stock springs are too stout. Not wanting to change shocks yet as I have modded these so they don't leak. So far, so good. What would be a good soft spring to start at? Should I change the length? I am also going to add a rear sway bar to help with some torqe twist. Thinking of adding a little stiffer spring to help with the torque too. Any ideas? Thanks for the help guys! Last edited by Wacki; 12-26-2013 at 12:03 PM. Reason: kant sphell |
12-26-2013, 12:38 PM | #2 |
Rock Stacker Join Date: Jan 2007 Location: Carson City
| Re: Stock shock spring
Here's a list of the Axial part number, color, & spring rate. Hope this helps you out. I do beleive the stock springs are the reds ones at 2.07. hight the number the stiffer the spring the lower the number the softer the spring. AX30222 Blue 3.55 AX30221 Yellow 3.27 AX30220 Green 2.85 AX30219 White 2.47 AX30218 Red 2.07 AX30225 Orange 1.75 AX30224 Purple 1.43 AX30223 Black 1.07 I beleive that's all of them. |
12-26-2013, 12:42 PM | #3 |
Great! THANKS
12-26-2013, 03:25 PM | #4 |
Newbie Join Date: Jul 2013 Location: romania
Not wanting to change shocks yet as I have modded these so they don't leak. What mod did you make to stock shocks so they don't leak any more? |
12-26-2013, 09:16 PM | #5 |
| Re: Stock shock spring I took them apart and used thin teflon tape on the top cap. Used some green slim on the bottom. Tightened very tight. So far so good! |
12-26-2013, 09:50 PM | #6 |
Pebble Pounder Join Date: Jun 2009 Location: Selah
I put losi gold springs on mine they work awesome
12-26-2013, 10:34 PM | #7 |
| Re: Stock shock spring |
12-26-2013, 10:39 PM | #8 |
RCC Addict Join Date: Mar 2013 Location: Oklahoma City
Get the axial black springs....perfect spring
12-27-2013, 02:08 AM | #9 |
I'm thinking of picking up some of the Axial purple for the front & black for the rear. I figure it can't hurt to have some of each color to fine tune the stock shocks. |
12-27-2013, 08:08 AM | #10 |
I can't remember the part number, but they are soft but still enough stiffness that it's stable
12-27-2013, 08:41 AM | #11 |
The purples come on the kit wraith and I have never seen a need to change them.
12-27-2013, 06:50 PM | #12 |
Rock Crawler Join Date: Jan 2007 Location: West Seneca
| Re: Stock shock spring With the battery mounted up front this is what i ran and it felt great. Have golds all the way around on it now and doesnt feel as good.
12-28-2013, 01:11 AM | #13 |
RCC Addict Join Date: Jul 2009 Location: Ontherocks
I run purples all around. Im not one to spend hours and hours tuning my suspension, but they work great for me
Stock shock spring - Similar Threads | ||||
New Shock (inner spring) | megapro | Axial SCX-10 | 4 | 08-02-2013 10:09 AM |
bj shock n spring help | drpuffmd | Axial XR10 | 11 | 12-30-2011 11:35 AM |
Set up tips with stock chassis and shock spring question | Interceptor | HPI Wheely King | 4 | 09-29-2011 02:01 AM |
Shock oil and shock spring help | entropy | General Crawlers | 10 | 01-29-2011 08:40 AM |
Internal spring/ and stock spring set up | wassaakk | Newbie General | 7 | 06-06-2010 06:53 PM |
