02-14-2014, 09:03 PM | #1 |
Quarry Creeper Join Date: Jun 2013 Location: San Francisco
| Sway bars with Curries?
I'm running VP Curries front & rear, and I'm trying to figure out a way to mount the Axial sway bars. Here's the problem: Normally, they'd attach at the axle, via the shock mount bolt, just inboard of the mount. On the stock axles, there's just enough clearance between the pumpkin & the shock mount for it all to work. On the Curries, there's just not enough space. I know the easy thing is just to leave them off, but this is going to be an Ultra4 rig, so they will be a necessary piece of equipment to have figured out. Anyone else run into this before? Creative solutions? |
02-14-2014, 09:35 PM | #2 |
Quarry Creeper Join Date: Nov 2010 Location: Canada
| Re: Sway bars with Curries?
You bet its possible. When I swapped over from my VP AR60 housings I ran into this issue aswell. I found some different balls for the lower mount. They are threaded. I put these on with a bit of Loctite and did away with the nuts. If you look closely, you can see a hex shape in one end of the ball. You may need to find a shorter screw to use so you can get a hex driver in the ball. Serpent 5.8mm Aluminum Coated Pivot Ball Set (4) [SER804252] | RC Cars & Trucks - A Main Hobbies Here is the part # in case the link quits.... SER804252 |
02-14-2014, 09:57 PM | #3 | |
| Re: Sway bars with Curries? Quote:
Sway bars with Curries? - Similar Threads | ||||
Sway bars | Jus | Vaterra Twin Hammers | 6 | 12-18-2013 07:00 PM |
sway bars | vito | Newbie General | 7 | 08-10-2013 07:59 PM |
Sway Bars?? | ESC | Axial Wraith | 14 | 08-06-2012 08:12 PM |
Sway Bars | Optiskate | Axial SCX-10 | 13 | 03-03-2012 11:03 PM |
Sway Bars | Slowsteve | Axial Wraith | 8 | 08-22-2011 11:59 AM |
