03-01-2014, 03:43 PM | #1 |
Quarry Creeper Join Date: Oct 2011 Location: Westport Island
| help me decide what to power my wraith with
Howdy, I know this has been cover a gazillion times but I need a little help. I want to re power my wraith (stock motor,esc) I wanted to go sensored brushless but I have such little knowledge on brushless motors I dont know what to look for, I dont mind staying brushed but again, Im not sure which way to go. I would like to stay 2s lipo and its current top end with stock gearing is fine, just looking for a little more torque and efficiency. Thank you, Mr. Indecisive |
03-01-2014, 03:47 PM | #2 |
| Re: help me decide what to power my wraith with
Hands down the best deal on a sensored motor for the wraith is the HobbyWing 3400kv 3656SD. It fits without modification. It is a 1500w (pro4 is 1000w) 4 pole. The fact that it is less than $90 shipped seals the deal.
03-01-2014, 04:15 PM | #3 |
Quarry Creeper Join Date: Feb 2011 Location: Litchfield park
Agree with Calderwood. I also would recommend the Tekin Redline 13.5t. Picked up used for $30 on the forums. 4 pole is better for torque but if budget is in your mind you can always look at 2 pole motors. Mine did fine with the 13.5 but I upgraded to the Tekin ROC 412 3100kv motor. AMAZING. You'll need a new ESC also to run sensored brushless. I think most people run the Castle MMP. Personally, have a little hatred towards Castle so I run the XeRun ESC. Runs the Tekin and Hobbywing motors like a champ. Good luck picking! |
03-01-2014, 05:46 PM | #4 |
Rock Crawler Join Date: May 2012 Location: Minneapolis
Take a look at the new holmes hobbies brushless motor. It's 3100kv and sensored. It is 2 pole but John designed it with crawling/trailing in mind so it really performs. The 2 pole motors give you a little better slow speed start than most 4 poles. For esc. I run castle mmps. They are so versatile and will work great. Good luck. |
03-01-2014, 06:11 PM | #5 |
Quarry Creeper Join Date: Jun 2013 Location: South jersey
Calderwood is spot on, get the Hobbywing 4-pole and a MMP. I just installed one in my wraith, and I thinks it is the single best upgrade I have ever purchased for any RC car I've owned. It is smooth as glass and has retard strength for torque.
03-01-2014, 06:52 PM | #6 |
That's my favorite kind of torque!!! Great suggestions guys, Ill check out both systems, not familiar with hobby wing stuff but I do have a HH combo in a crawler, it runs really well. I need to get educated on brushless motors, I get confused with kv's versus turns. Sent from my iPhone using Tapatalk |
03-01-2014, 09:43 PM | #7 |
Quarry Creeper Join Date: Dec 2008 Location: Santa Mira
Search your feelings. What does your heart tell you?
03-02-2014, 05:13 AM | #8 |
ugh....Too many choices! my heart tells me to stay brushed (I run in the snow sometimes) and it tells me to catch up with the times and run brushless! I like the idea of HH products, support the smaller guy kinda thing |
03-02-2014, 07:08 AM | #9 |
| Re: help me decide what to power my wraith with I waterproofed my 3656SD wth mg chemicals 419b conformal coating and regularly submerge it completely under water.
03-02-2014, 07:16 AM | #10 |
Rock Crawler Join Date: Nov 2013 Location: In the country
Is sensorless waterproof? Sent from my LG-E980 using Tapatalk |
03-02-2014, 07:23 AM | #11 |
Is a 17.5 turn decent? Sent from my LG-E980 using Tapatalk |
03-02-2014, 06:27 PM | #12 |
| Re: help me decide what to power my wraith with It depends on the system. Realize though that $10 of the conformal coating that I mentioned above is enough to 100% fully waterproof every receiver, BEC, servo, speed control, and motor that you own. When you are dealing with brushless motors turns aren't a very good way to pick a motor. The combination of watts and Kv are the best way to compare brushless motors. |
03-02-2014, 09:26 PM | #13 |
I won't buy a motor that does not list kV. Um currently crawling with a 950kv motor on 3s and love it. Enough wheel speed to be at the lower end of rock bouncing with 800 watts of power |
03-03-2014, 06:05 PM | #14 |
Rock Stacker Join Date: Mar 2013 Location: Mobile
Just ordered this combo for my new Wraith kit I just finished, will be taking pics of it tomorrow! HobbyWing JS6 Sensored Brushless Combo w/ Justock 45A ESC + XERUN-21.5T 1600kv Sensored Motor is the combo I ordered for around 113. dollars.
03-04-2014, 12:04 PM | #15 |
Pebble Pounder Join Date: Nov 2010 Location: Simi Valley
I would go with a Tekin 17.5t and a mamba max pro. It is a great, reliable combo and has plenty of torque and wheel speed. Don't get the RPM model 17.5 unless you want a LOT more wheel speed. With my gen 1 17.5 I get plenty of speed and torque. I run a Tekin RX8 with it, but a mamba max pro would work just fine as long as you get the castle link to set a drag brake for it.
03-04-2014, 01:12 PM | #16 | |
Newbie Join Date: Mar 2014 Location: USA
| Re: help me decide what to power my wraith with Quote:
The statement about KV vs watts is a good one. it is a bit deceiving though. a higher kv motor will have higher wattage but less torque. I personally prefer extreme low KV and higher voltages! Chris | |
help me decide what to power my wraith with - Similar Threads | ||||
Need some hands on wraith/TH experience to help decide which to buy | 253Bigfoot | Newbie General | 0 | 08-06-2013 08:13 PM |
Is This TOO MUCH POWER for a Wraith?? | alexchen86 | Electronics | 14 | 05-16-2013 10:57 AM |
wraith or sx10 vid to help decide wich | evan03 | Newbie General | 1 | 04-22-2013 08:45 AM |
