07-22-2014, 08:39 PM | #1 |
Newbie Join Date: Jun 2014 Location: Hampton
| Wraith motor swap
Hello fellow crawlers, I have a PS Wraith and am planning on switching out the stock motor for a Holmes Hobbies Crawlmaster Expert 13T. My main question is whether or not the stock ESC can run that particular motor. I have a Castle BEC installed due to running a Savox 1256 servo so that part is out of the way. I appreciate any and all information! -Josh |
07-22-2014, 09:02 PM | #2 |
| Re: Wraith motor swap
The CrawlMaster 13T is a 5 pole motor so it is approximately equal to a 27T 3 pole motor. The Axial AE2 can handle down to 19 turns so it will work with the CrawlMaster 13T. AE2 Specifications: Input Voltage – 6 cell NiCad/NiMH or 2cell lipo** Size – 1.7″ x 1.24″ Weight – 45 Grams Motor Limit – 19t On-Resistance FET – .0018 Rated/Peak Current – 106A Peak Braking Current – 106A Peak BEC Voltage – 5.0V/2A Peak PWM Frequency – 6KHZ **You can run higher voltage batteries such as a 7 cell NiCad/NiMH or 3 cell lipo with the installation of a “Castle BEC” |
07-23-2014, 08:32 AM | #3 | |
Rock Crawler Join Date: Jun 2013 Location: Knox, IN
Do yourself a favor and get a Castle BEC, if you don't already have one! Quote:
07-23-2014, 02:08 PM | #4 |
Quarry Creeper Join Date: Mar 2014 Location: LI
My 13t runs great on the stock ESC. Haven't had any problems with 3s and BEC.
Wraith motor swap - Similar Threads | ||||
wraith motor swap info | bign | Axial Wraith | 13 | 05-30-2013 06:19 AM |
Motor swap | xjchase | Venom Creeper | 7 | 03-19-2013 08:40 AM |
My motor swap. | redrokin00XJ | Redcat Crawlers | 23 | 02-23-2011 02:58 PM |
Motor Swap. | Greatscott | Axial AX-10 Scorpion | 5 | 01-15-2009 05:53 PM |
motor can swap | djjiz | Newbie General | 16 | 05-30-2008 03:44 PM |
