03-15-2013, 11:57 AM | #1 |
Newbie Join Date: Mar 2013 Location: Crawfordsville
| Motor swap
I would like some opinions. I bought a novak 55t terra crawler motor for my venom but when I try to take the motor plate screws out they just try to strip. Dont really no what to do . I personally didnt put the crawler together so I have no clue if there is another way to get the motor out another way.
03-15-2013, 12:25 PM | #2 |
Rock Crawler Join Date: Jan 2013 Location: Middleburg Florida
| Re: Motor swap
you should be able to pull the rubber plug out on the opposite side of the motor and get to the 2 motor mount bolts. Unless it has a pinion bigger then 20 tooth the big plate can stay on the gearbox.
03-15-2013, 12:48 PM | #3 |
| Re: Motor swap |
03-16-2013, 07:06 AM | #4 |
| Re: Motor swap
did you get it?
03-16-2013, 07:28 AM | #5 |
RCC Addict Join Date: Jun 2011 Location: Lindsborg
Do the heads of the fastener strip? You could use a torx bit. Sent from my RM-845_nam_vzw_100 using Board Express |
03-16-2013, 10:32 AM | #6 |
| Re: Motor swap |
03-16-2013, 10:35 AM | #7 |
| Re: Motor swap |
03-19-2013, 08:40 AM | #8 |
| Re: Motor swap
I doubt that, I had one do it to me on a used unit i bought. The combination of the plastic compound used and the threads on the fasteners and the cheap material used for fasteners all lead to this happening. i got lucky and only had one do it, you weren't so lucky. there is no reason for that type of thread used on these screws.
Motor swap - Similar Threads | ||||
My motor swap. | redrokin00XJ | Redcat Crawlers | 23 | 02-23-2011 02:58 PM |
Motor Swap | Grave95 | Newbie General | 3 | 10-15-2009 11:32 PM |
Slash motor swap? | XPLORx4 | Non Crawler RC's | 2 | 04-16-2009 08:39 PM |
Motor Swap. | Greatscott | Axial AX-10 Scorpion | 5 | 01-15-2009 05:53 PM |
motor can swap | djjiz | Newbie General | 16 | 05-30-2008 03:44 PM |
