03-25-2014, 06:32 PM | #1 |
Pebble Pounder Join Date: Mar 2014 Location: U4IA Oregon
| Hot racing steel gear set HELP!
I have an Axial wraith If I where to buy this hot racing steel gear set 52t 28t 20t Hot Racing Axial Wraith Lightweight Steel Gear Set SSCP1000X | eBay What would be the motor i would need to match it? and is it for crawling or speed? Desperately trying to find a motor and gear setup solution! I want to crawl and not stress out my motor most people say 84t 16t for crawling with stock motor but what about the 3rd gear in there? Thanks for your help! |
03-25-2014, 06:41 PM | #2 |
Pebble Pounder Join Date: Jun 2009 Location: prairie du sac
| Re: Hot racing steel gear set HELP!
Those are for inside the transmission to replace stock gear set. You are thinking about spur gear and motor pinion
03-25-2014, 08:25 PM | #3 |
Rock Stacker Join Date: Jan 2012 Location: Vancouver
The gear ratio chart on the Robinson Racing site is helpful. Stock wraith spur and pinion gears equate to roughly 4:1if im not mistaken. You're going to want to find a spur/pinion combination that equals anywhere from 5:1 to 6:1 if you're wanting to crawl. The transmission gears you ordered are just a strength upgrade. They dont really have much to do with motor speeds, torque, gear ratios blah blah blah
03-25-2014, 08:38 PM | #4 |
Rock Stacker Join Date: Jan 2014 Location: Reseda
84t/16t is fine for crawling. I run 87t/20t with a Tekin T35HD for my crawler Wraith.
03-25-2014, 09:33 PM | #5 |
Quarry Creeper Join Date: Apr 2006 Location: sweethome
I have the stock 80 20 in mine with a 35 t and love it .I have the 32 pitch set from ckrc that match the stock ratio ill be putting in when the stock ones go south,It crawls great and has pretty good wheel speed .
03-25-2014, 10:37 PM | #6 | ||
do you need a new esc when putting in the 35t motor? Last edited by THX_138; 04-28-2014 at 12:16 AM. | ||
03-26-2014, 06:29 AM | #7 |
Quarry Creeper Join Date: Dec 2005 Location: Orrington
No you will not need a new esc to run the 35 turn. I would suggest adding a bec though
03-26-2014, 09:29 AM | #8 |
Rock Crawler Join Date: Jun 2013 Location: Knox, IN
Yes you need a BEC!
03-26-2014, 10:18 AM | #9 |
| Re: Hot racing steel gear set HELP! okay. what is a BEC ? so if i buy this 35t motor Tekin 35T Pro Hand Wound Rock Crawler Motor TT2122 | eBay and this 87t spur Axial AX30672 SCX10 AX10 Wraith Spur Gear 48DP 87T | eBay with stock 20T pinion will I be good to go at that point? thanks for all your help |
03-26-2014, 05:48 PM | #10 |
Quarry Creeper Join Date: May 2008 Location: Out in the country
[QUOTE=ChronicCrawler;4722935]okay. what is a BEC ? B.E.C= Battery Eliminator Circuitry Castle creations 10amp costs about $20-25. Your lhs should have them in stock or just about any of the hobby sites if you order online. |
03-26-2014, 07:16 PM | #11 | |
[QUOTE=scrounge;4723477] Quote:
it looks like I got the gears on there way to me , but I haven't even thought about installing them. I have never taking anything apart ha ha 0 exp. | |
03-26-2014, 07:58 PM | #12 |
Newbie Join Date: May 2012 Location: Truckee
| Re: Hot racing steel gear set HELP! Hey Guys!!! I am not trying to hi jack this thread, just learn a little. I have purchased a Wraith for my 9 year old, and he has already stripped out the stock plastic spur gear in less than a day and a half No worries, i guess it is the name of the game..... So while i was at my local hobbie shop picking up 2 new spur gears in case it happens again, they also told me the stock wraith motor is the weak link, so i also purchased another stock 21 wound motor to replace the original one when it takes a crap. Tonight he brought the Wraith in saying the motor was smoking , it was so hot to the touch it almost burned my finger, so i would say it is on its way out. So i have been looking into buying a up graded motor for his Wraith after the new stock one i already purchased burns down... I see that a new BEC is recommended with a up graded motor. After doing some research is see the BEC is mostly used in R/C airplanes in-case the battery voltage drops enough to kill the motor, but you still have enough juice to navigate the plane and land it safely. So my question is why the BEC in a crawler, is it like a safety device to keep from burning the motor down in low voltage??? Another question i have i see there is 21 turn motor which his is stock, then the # grows from there, is the higher the # a slower or faster turning motor. When i up grade his stock motor, he is not so much into going slow and crawling in our dried up creek bed next to our house as he is into going fast and tearing it up... Sorry for the stupid questions, just trying to learn what i can about his new toy so i make the correct decisions on the up grades. Rick Last edited by maddogs1965; 03-26-2014 at 08:04 PM. |
03-26-2014, 10:20 PM | #13 |
I am running the teken 35t pro and 54 /14 32 p gears and love it with the stock esc and CC bec
03-27-2014, 08:56 AM | #14 | ||
Rock Crawler Join Date: Apr 2004 Location: Not where I belong.
| Re: Hot racing steel gear set HELP! Quote:
Choosing a motor and ESC for your Wraith - Gearing Added! If your son is interested in going fast, I would suggest at least skimming through Harley's budget build thread. He does a pretty good job of showing the common weak points of the wraith such as gears, links and dogbones. The ESC serves two purposes. One is to send power to the motor and the second is to send power to the receiver and servo. When the amp draw from the servo is too high it can cause the esc to loose function or kill the esc. These problems are more common with larger or multiple power hungry servos. In this application the BEC supplies power to the receiver and servo bypassing the esc which allows the esc to not need to work as hard. Also the BEC can be set to supply more volts to the servo whereas the the esc has a fixed setting. There are a few different ways to wire a BEC but this is the most basic explanation. | ||
03-27-2014, 09:21 AM | #15 |
Pebble Pounder Join Date: Dec 2013 Location: Burbank
Use a BEC.
03-27-2014, 02:43 PM | #16 |
If you have a wraith you Must have a BEC
03-27-2014, 04:43 PM | #17 |
| Re: Hot racing steel gear set HELP! |
03-27-2014, 05:28 PM | #18 | |
Pebble Pounder Join Date: Jan 2013 Location: DENVER
35T is right in the middle of the road for speed, 55T is slow 10T is fast. stock 20T has zero torque, the tekin has torque. with his gearing 54/14=3.157:1 ratio is geared for speed. his setup is probably similar to stock speed but with some torque, slower motor, faster gearing. To figure out your gearing ratio take your spur÷pinion=ratio (stock 80/20=4:1) so the pinion will rotate 4 times and the spur will rotate 1 time. Last edited by WAFFLE; 03-27-2014 at 05:36 PM. | |
03-27-2014, 05:36 PM | #19 | |
03-27-2014, 05:39 PM | #20 |
Im way ahead of you |
Hot racing steel gear set HELP! - Similar Threads | ||||
Hot Racing Aluminium Tranny Gear and OD/UD gear | Colgout | Axial AX-10 Scorpion | 10 | 10-01-2012 04:57 PM |
Hot Racing hardened gear set issues... | Charlie-III | Axial XR10 | 20 | 09-15-2012 08:44 AM |
