Thread: Which springs for Gmade xd piggys
Old 03-24-2014, 11:33 PM   #1
Default Which springs for Gmade xd piggys
Hey all, building my crawler/basher Wraith PS and got some clean used gmade 103mm xd piggys but they have strange mismatched springs. From a re really long and rears are almost too short.
I have a droop kit on my wraith and care mostly about trail cruises amd crawling.
What spring are recommended for this?
Soft gmade 58mm springs or ???
Thanks for any suggestions. Pics a plus
Jon
J5races is offline   Reply With Quote
Old 03-25-2014, 10:34 AM   #2
Default Re: Which springs for Gmade xd piggys
For the 103mm you want the 19x68mm.
Suspension
cody426 is offline   Reply With Quote
Old 03-25-2014, 11:46 AM   #3
I know that, but which? Soft, med, hard?
Old 03-25-2014, 12:24 PM   #4
That depends on a few different things, if your rig is stock try the soft ones. The reason I posted a reply was you had mentioned the 58mm and I wanted to point out the 103mm shocks are 68mm springs. I have been trying to figure out in the last few days which springs come with the shocks, no luck. Mine do not seem to have a color marked on them like the ones on RPP's site, but I would assume they come with mediums based on what I have read so far. I was just going to order the soft springs and try them out.
You don't necessarily have to use gmade springs either, here is a post on rcshortcourse of some folks trying different springs.
Gmade XD Aeration shocks - RCShortCourse
Old 03-25-2014, 07:48 PM   #5
Ok, right. I checked their site this morning and figured out 68mm was what I needed.
I ended up ordering softs and a pair of medium to see what works for me.
Thanks for the Link, seems some other springs will fit if I'm unhappy with the glades after playing with them.
Thanks for your time
Old 03-25-2014, 09:19 PM   #6
I'm using Proline rear slash shock springs on my 103mm g-made piggybacks. They work great and the soft set is softer then the g-made springs. I'm even using the slider that allows you to use the second tender spring. There are pictures posted in the g-made section. And yes, both brands of springs are marked so that you can keep the stiffness strait. Proline sells a spring assortment, soft, med, and hard.
Slowpony is offline   Reply With Quote
Old 03-26-2014, 10:26 AM   #7
Do you know where to get the slider without purchasing the entire rebuild kit? I like this option but purchasing two $11 rebuild kits for just the sliders makes it a tough buy.
Old 03-26-2014, 11:24 AM   #8
Sorry, no. I had to buy the rebuild kit, cheapest on flee-bay, so you'd need two spring assortment sets and two rebuild kits for the sliders. I'm sure they would be easy to machine from delrin but I don't have access to a lathe. I even looked for a PVC or urethan tubing option with no luck. But buying the rebuild kit is a pain for just the two plastic parts.
Old 03-26-2014, 12:28 PM   #9
I've also used T-maxx red and slash progressive springs. Depends on the setup you want. As stated above, the Proline powerstroke for slash rear springs fit. You either need the spacer to run the 2 stage, or just move the adjustment collar down and run the larger proline spring.
dna4engr is offline   Reply With Quote
Which springs for Gmade xd piggys - Similar Threads
Gmade piggys Straxus Axial Wraith 10 02-02-2014 10:20 AM
Need help with springs for Gmade shocks on my Wraith NCT_Guy Axial Wraith 12 01-07-2014 09:20 AM
Gmade piggys or icon? Beej Axial SCX-10 13 08-03-2013 10:29 AM
Gmade piggyback XDs springs cytogen G-Made Crawlers 25 03-20-2013 12:25 PM
