Thread: ring/pinion over engauging...
Old 04-23-2014, 09:48 AM   #1
~THE SCALE SHOP~
Question ring/pinion over engauging...
first of all i need to admit im a complete Ar60 newb. putting together my first axles
i did some searching and didnt come up with anything about this. just the bearing failures.
im having trouble with my pinion gear over engauging into the ring gear. i first thought i had a motor/esc issue, and started removing peice by piece to find the problem. finally when i had bare axles in my hand i found the problem.
if you push in on the pinion gear it will notchy/hard "spin" about 2 teeth, then completely lock up. wont spin, ease up, twist, and push in and it will spin another 2-3 teeth and then lock up again as you press in. does the same thing when on the truck and driveshafts hookuped up and powered by motor/trans.
every single part is brand new.
if you pull out on the pinion gear and spin it, it spins free and smooth.
does this with both Stock and HD UD/OD gears.
anyone else experienced this?
STANG KILLA SS is offline   Reply With Quote
Old 04-23-2014, 10:08 AM   #2
Default Re: ring/pinion over engauging...
Ive seen this with the HD gears, just grease them, spin them with a drill for a bit and run them.
Also, make sure the inner pinion bearing is set all the way in, some take a good amount of pressure to seat all the way. This typically is the culprit
Erin is offline   Reply With Quote
Old 04-23-2014, 11:56 AM   #3
Since you say it only does it when you push in on the pinion the typical shimming between the outer pinion bearing and the yoke will cure it.
Calderwood is offline   Reply With Quote
Old 04-23-2014, 12:44 PM   #4
That's a fact. I've had good luck with traxxas teflon shims. Some of my gears need to shim the pinion in by putting the shims behind the head of the pinion and the inner bearing. Some need to go out by shimming between the driveline and the outer pinion bearing.
WHITE-TRASH is offline   Reply With Quote
Old 04-23-2014, 01:03 PM   #5
~THE SCALE SHOP~
i thought about running a 5mm Thick outer pinion bearing instead of the stock 4mm thick.
instead of shims.
i dont have either so id have to order something anyway. i figure the bearing would be easier to not have to keep track of as im changing driveshafts etc.
anyone ever do this? thoughts?
teflon shim part #?
Old 04-23-2014, 01:08 PM   #6
RCP Crawlers, Traxxas, they both make teflon shims, like Frank's Red Hot, I use the chit on everything!
TheAxialNut is offline   Reply With Quote
Old 04-23-2014, 01:15 PM   #7
TRA1985 Any hobby shop that stocks traxxas stuff should have them on the shelf.
Old 04-23-2014, 01:20 PM   #8
Yes this, I had to put shims between the driveline and outer pinion also. It removed the slop and stopped the gears from meshing too tight. I used an associated sc10 rr hub bearing spacer. I had to cut to length and open the inner diameter. It was a little work to do but I have zero play with a good solid mesh. The stock bearing are holding up fine even on 3 cell and rock412 3100 KV motor
lala4fire is offline   Reply With Quote
ring/pinion over engauging... - Similar Threads
Ring and Pinion #'s rockslyder Vaterra Twin Hammers 2 10-21-2013 05:09 PM
Helical ring and pinion gears sets with an offset pinion? Calderwood General Crawlers 6 09-14-2013 09:06 PM
ring and pinion luv2ridemx Axial Wraith 4 12-16-2011 11:02 AM
Ring and Pinion Garry Venom Creeper 6 10-11-2010 04:30 PM
36/14 ring and pinion? JaredVW Axial AX-10 Scorpion 10 11-09-2009 08:00 PM
