Thread: Does anyone run a Pro4 4000kv?
Old 04-23-2014, 07:24 PM   #1
Default Does anyone run a Pro4 4000kv?
Just what the title says. Just curious. I know that's a lot a motor but I'd like to see it!
Sent from my SCH-I545 using Tapatalk
Markeje is offline   Reply With Quote
Old 04-23-2014, 07:30 PM   #2
Default Re: Does anyone run a Pro4 4000kv?
I used to but I switched to the Pro4 4300 HD. The HD has a smoother power band.
frdtrkguy is offline   Reply With Quote
Old 04-23-2014, 07:33 PM   #3
I run a 4000kv..
winnerone23 is offline   Reply With Quote
Old 04-23-2014, 08:48 PM   #4
Running a Pro4 3300kv with the RC4WD AX2 2 speed tranny in my wraith project. Plenty of wheel speed to suit my tastes in high gear, and the crawl-ability I desire in low. I love it so far, but I dont have as much experience with it as some others here.
And isnt that Wraith Buggy "Crunchy"? Careful with the high powered motors, you'll end up with a small fortune invested by the time its all said and done.
Sevastra is offline   Reply With Quote
Old 04-23-2014, 08:52 PM   #5
Lmao... That dam Viper! Yeah, that's the Sexo, now known as Crunchy.. Hahahaha...
Old 04-24-2014, 09:29 AM   #6
So does the 4000kv actually fit in the wraith or is there some trimming to be done where the back right link support/connection?
I know the Pro4 3100 fits fine. However I needed to trim a little off of the link support for the Roc412 3100kv to fit. I'm running 32p 56/15.
Old 04-24-2014, 09:35 AM   #7
It did the same as the 3100.. Same can size.
Old 04-24-2014, 10:02 AM   #8
I realize the 4000 is the HD version. So it's a tad longer. But it should have better low end supposedly.
Old 04-24-2014, 10:04 AM   #9
I have the 4000kv and it was handful, even on 3S. I had to keep it geared down.
Szczerba is offline   Reply With Quote
Old 04-24-2014, 10:30 AM   #10
Ya I think I'm going end up throwing it up on the classifieds. Or maybe trade for something.
Old 04-24-2014, 10:31 AM   #11
The 4000 I had was the short can. The 4300 HD that I run now is the longer can.
Old 04-24-2014, 11:19 AM   #12
Hey frd. You had to remove some material from the link area right?
Old 04-24-2014, 11:21 AM   #13
I cant help. My rig doesn't have the stock wraith skid. I think I read that the upper rear link mount has to be trimmed to fit a 550 motor.
Old 04-24-2014, 02:00 PM   #14
Cool. Ya I know it. Heck just to get the roc 412 installed I had to trim some.
Old 04-24-2014, 05:09 PM   #15
I had to trim to fit my hobbywing 3656sd 3400kv.
Cmarcan167 is offline   Reply With Quote
Old 04-24-2014, 11:40 PM   #16
Its a lot of kV but nor much power . Its under 1500 what's
Had to trim to fit my turnigy 1/8 scale. 2650 watts on 5s.
This motor amazes the tekin powered rigs around here
Even clearenced the cooling rips off the motor to clear with 56/14 gears
evan03 is offline   Reply With Quote
Old 04-28-2014, 06:41 AM   #17
How do you keep your drive train together with all power?
Old 04-28-2014, 10:30 AM   #18
You dont, you just listen for the snap and then do your next round of upgrades.
In reality you just take it easy on the throttle in areas where something can get bound up. If you've got a heavy throttle finger and are always going full blast then having a 4000kv motor might hurt your pocket book with the repairs.
Old 04-28-2014, 10:53 AM   #19
: thumbsup: That's how I do! ;)
Old 04-28-2014, 09:10 PM   #20
Me too. Stripped a trans gear on my pro4 3300 powered Wrexo this weekend, time for HR steel gears. Next.....
J5races is offline   Reply With Quote
Does anyone run a Pro4 4000kv? - Similar Threads
Anyone running Pro4 4000kv? cjthing Axial Wraith 11 02-22-2013 05:00 PM
Pro4 3300 vs 4000kv chris_snchez Electronics 2 02-03-2013 08:56 PM
