05-12-2014, 10:19 PM | #1 |
Pebble Pounder Join Date: Feb 2014 Location: Sweden
| Vanquish 12mm Clamping Hex Hub Vanquish Products 6061-T6 aluminum 12mm hex hub Clamping hex helps alleviate pin breakage, when stub shafts rotate and hex does not Tighter tolerances for better stub shaft fitment Anyone running these? Couldn't really find any review of them. I would like to know if they really reduce slop. |
05-13-2014, 12:05 AM | #2 |
Pebble Pounder Join Date: Feb 2012 Location: Aurora
| Re: Vanquish 12mm Clamping Hex Hub
I'd like to try a set.
05-13-2014, 05:27 AM | #3 |
Rock Crawler Join Date: Dec 2011 Location: Blacksburg
I got a set about a week ago. They where extremely tight fitting. As in I had to stick a screwdriver in the slot and take the old hex and beat them on. Not sure how I am going to get them off later. Also I tried to get my monsters on and for some reason they where tight using these hexes.but they do reduce the slop.LOL
05-13-2014, 01:04 PM | #4 |
Great to hear I should get a set then.
05-18-2014, 08:58 AM | #5 |
Just got mine in this morning. Wow, they are awesome! I did have to kinda tap them into place. I can't believe how much slop my axial hexes introduced into the drive train!
05-18-2014, 01:09 PM | #6 |
Sounds good, I'm waiting for mine. Ordered 2x2 from supershafty |
05-19-2014, 03:48 PM | #7 |
Pebble Pounder Join Date: Feb 2012 Location: Freakville
I had a difficult time installing them due to the tight tolerance. I used the screwdriver method to spread the clamp and them used a rubber mallet to tap them in place. The rears went on fairly easy but the frons were tougher sliding the hex over the AR60 universals.
05-19-2014, 03:55 PM | #8 |
Quarry Creeper Join Date: Dec 2010 Location: Australia
I had to drill mine fark they were tight
Vanquish 12mm Clamping Hex Hub - Similar Threads | ||||
Stock 12mm hex hub | Steve Hipsley | G-Made Crawlers | 6 | 03-04-2012 09:17 PM |
12mm hex hub? | rod-211 | Axial SCX-10 | 2 | 04-05-2011 04:56 PM |
Vanquish SLW V3 on Bully Axles which hex hub size???? | vodka child | RC4WD Bully | 17 | 07-16-2010 10:43 AM |
12MM Hex Hub Adapter | jmizoguchi | Axial AX-10 Scorpion | 3 | 11-26-2007 03:13 AM |
