04-28-2015, 03:00 AM | #1 |
Rock Stacker Join Date: Dec 2014 Location: Australia
| rookie currie question
hey guys, got a poison spider, few mods, one includes full vanquish titanium link kit stock axles, c hubs and knuckles on it at the moment, what else do i need specifically to run the vanquish diffs? Vanquish Aluminum Front Currie Axle Black Axial Wraith 1 10 RC CAR VPS06621 | eBay Vanquish Aluminum Alloy Rear Currie Axle Black Axial Wraith 1 10 RC CAR Crawler | eBay do i need to run specific links for them? do i need to run vp lockers? front driveshafts? rear axles? centre driveshafts? i am from australia and anything vanquish is hard to get so the ebay links are just for reference because thats the only way i can get them i beleive. will do more research on where to buy later |
04-28-2015, 05:19 AM | #2 |
Rock Crawler Join Date: Nov 2010 Location: the 'burgh'
| Re: rookie currie question
Your link set will be fine, I highly suggest MIP drive shafts and as far as your axles go, stuff them with the best parts you can afford. VP lockers are not necessary but do fit the best, I personally have found other lockers may need sanded a bit to fit proper. Hardened R&P gears should be a priority, VVD's are as good as anything out there and Axial's rear straight axle is fine. Do it right the first time and enjoy yourself out on the trail.
04-28-2015, 06:04 AM | #3 |
Newbie Join Date: Feb 2015 Location: duluth
Yep, enjoy and have fun rather than break and not be able to wheel it. Thats how i was this weekend
04-28-2015, 08:28 PM | #4 |
Rock Stacker Join Date: Feb 2010 Location: Phoenix
You can use all stock axial internals and cv's. Look at putting oilite bushings in the output instead of bearings.
04-29-2015, 01:22 AM | #5 |
Pretty sure the currie needs longer upper links... They do on scx..
04-29-2015, 07:20 AM | #6 |
Wraith curries work with stock links.
rookie currie question - Similar Threads | ||||
currie axle for yeti question | desertdude | Axial Yeti | 7 | 03-09-2015 05:34 AM |
Rookie question from a veteran builder | TheManCave | RC4WD Trail Finder 2 | 3 | 04-22-2014 09:02 PM |
VP Currie front axle question | Jus | Axial Wraith | 4 | 09-04-2013 01:55 PM |
Wheel question from a rookie | Philly116 | Redcat Crawlers | 11 | 03-19-2013 10:50 AM |
Rookie question. Wheel spacers needed? | iPhone pirate | Tires and Wheels | 0 | 11-12-2012 10:28 AM |
