03-08-2015, 03:31 PM | #1 |
Rock Crawler Join Date: Aug 2011 Location: SB
| currie axle for yeti question
Hello, I see their are 2 different rear currie axles for the yeti I think.. VANQUISH Currie Axial Wraith Rear Axle for $140.50 and VANQUISH Wraith & Yeti Centered Pumpkin Rear Currie Axle for $174.95. What is the difference besides the price. can ether be used. I see you have to reverse the front diff with the spendyer axle. Im confused Thanks |
03-08-2015, 03:52 PM | #2 |
Quarry Creeper Join Date: Feb 2012 Location: Arkansas
| Re: currie axle for yeti question
The center currie comes with axle shafts.
03-08-2015, 04:50 PM | #3 |
Wow $30 for axle shafts, well they are Vanquish so top quality, but this is very good to know as I will use the shafts that came with my kit. Thank you.. |
03-08-2015, 05:13 PM | #4 |
Rock Stacker Join Date: Jan 2015 Location: MD
The centered with VP shafts is much better. Might not matter to you unless you've had probs bending the stock axles though.
03-08-2015, 05:40 PM | #5 |
Are people bending them?
03-08-2015, 06:04 PM | #6 |
I bent mine, bashing. Not an issue if you're crawlin.
03-08-2015, 10:56 PM | #7 |
Do I need the vanquish 12mm wheel hexes to work properly, will the stock locker drop in or do I need to buy the Vanquish Locker? Thanks all Their is a thread on/for the wraith, I member got the centered currie for his wraith the currie that comes with the axle shafts, the shafts were abit to long, the solution its looks like they came to was use the Vanquish 12mm hexes? If this is the case I will probley buy the currie axle that I put my own axle shafts from my kit in. maybe I should stay away from this axle Last edited by desertdude; 03-08-2015 at 11:43 PM. |
03-09-2015, 05:34 AM | #8 |
The stock hexes and diff will work.
currie axle for yeti question - Similar Threads | ||||
Vanquish Centred Yeti Currie | Zombi | Axial Yeti | 18 | 02-09-2015 07:52 AM |
Yeti gearing question and Currie bearing? | ratrod63 | Axial Yeti | 2 | 01-18-2015 06:31 AM |
VP Currie front axle question | Jus | Axial Wraith | 4 | 09-04-2013 01:55 PM |
