01-15-2014, 08:19 PM | #1 |
I wanna be Dave Join Date: Sep 2005 Location: Dirty South
| Badd's Fusion 1.9 Wraith with SCX10 axles
I didn't take to many pics as I was building so this is more of a spec thread . I picked the name Fusion because of the mix of parts . Wraith Chassis with fast back mod . I used bent Tie rod and revo rod ends . I replaced the upper front bumper mounts with 80mm straight links to the back hole in front shock mounts . So I could run the servo on the axle . Front SCX10 Axle with Alum knuckles, hubs , hardend 38/13 bevel gear and stage 3 locker . Rear SCX10 axle stock . But will get underdrive gear soon . Rear upper and lower links 91mm Axial . Front lower links 70mm custom made . Front upper links 65mm Axial . Axial 4 link mount front and rear . 90mm Axial SCX10 shocks with red/red springs on front and red/green on the rear . I made custom shock mounts to gain 1/2 lift . the skid plate was very low . Now it has 2 7/8" clearance . PitBulls on a set of Buck~Shots . Mamba Max Pro with 35 lathe motor . (My 9 year will be driving this most of the time) Castel BEC Hitec 6545 servo Blue Lipo 2200 3s 11.1 Custom Spare tire mount . Dinky RC tall cowl hood . Custom Alum panels . I didn't have a pattern so I winged it . As for paint I went with Tamiya TS-20 metallic green and TS-6 matt black . I painted the hood and side panels green and the top and bed cover black . I trimmed out an old Proline Chevy grill sticker and made it work . The light stickers are from an old HPI sticker sheet . mockup wheels tires, I ended up going with 1.9 Pitbulls . Oh and the flex shots . This was a budget build . I gave $195.00 shipped for the new Dingo kit . I gave $77.21 for the new Wraith Chassis with interior . I gave $2.13 for the 5 big washers for wheel weights/ rock rings . $20.00 shipped for the dinky hood . $9.24 shipped for the lower links I cut to make the 70mm . The ESC, BEC , servo and screw and other odd items came out of my parts box . $303.58 spent out right not Badd . update on the cost 1.9 Pitbulls $59.97 The wheels I traded for . So final price is up to $363.55 Last edited by Badd; 02-03-2014 at 08:08 PM. |
01-23-2014, 05:07 PM | #2 |
| Re: Badd's Fusion 1.9 Wraith with SCX10 axles |
01-23-2014, 05:15 PM | #3 |
RCC Addict Join Date: Aug 2011 Location: round pond (aka clarksville TN)
looking good Andy, is this rig you building for your lil one?
01-23-2014, 05:18 PM | #4 |
01-23-2014, 05:30 PM | #5 |
yeah, makes them hard for us to sale/trade off if it's "THEIRS" |
01-23-2014, 05:40 PM | #6 |
01-25-2014, 09:20 AM | #7 |
01-25-2014, 09:22 AM | #8 |
Looks great. The wraith chassis lends itself to several build ideas. I have always liked the 1.9 tire builds. |
01-25-2014, 09:33 AM | #9 |
| Re: Badd's Fusion 1.9 Wraith with SCX10 axles Thanks man, I ended up using the Dingo I got from you . My daughter ran it all day New Years Day . I didn't set it up just added Servo, esc and motor . She had fun even if it was a little hard to drive . I told her if she wanted to go I would build something that would work a lot better . So Fushion was born . I just hope it work as good as it looks . |
01-27-2014, 06:46 AM | #10 |
The pics from yesterdays run . The only problems with this setup is 1) The rear springs where to soft . I had put red/red on the rear . I'm going back to red/green . 2) The rear was alitte heavy . I removed the alum wheel and replaced it with a plastic stock one . I did add the beadring to the stock one for looks . 3) The rear upper links need to be raised some how on the chassis . The rear wants to squat under load . Parts ordered from Duuuuuuuude to fix the problem . Last edited by Badd; 01-27-2014 at 03:25 PM. |
01-27-2014, 09:59 AM | #11 | |
These 1.9 rigs look fun, I've been considering one myself. Quote:
01-27-2014, 02:16 PM | #12 | |
| Re: Badd's Fusion 1.9 Wraith with SCX10 axles Quote:
I'm waiting for the pay-pal invoice for the risers . Last edited by Badd; 02-01-2014 at 05:57 PM. | |
01-27-2014, 02:52 PM | #13 |
I did a similar rig...even green lol...but i havent had an issue with the rear links...what was the issue with yours?
01-27-2014, 03:34 PM | #14 | |
The upper links are close to horizontal . Without separation (slightly up at the chassis) the rear want to squat under load . This hurts you on climbs as the front tires lift and the back of the chassis squats under . Only one thing happens you roll over . This from Duuuuuuuude will help this problem . http://i40.tinypic.com/282jscl.jpg Last edited by Badd; 01-27-2014 at 03:37 PM. | |
01-27-2014, 03:40 PM | #15 |
I see...i am running crawler king shocks..they are 110mm i think...explains why i havent had an issue...
01-27-2014, 04:13 PM | #16 |
Newbie Join Date: Nov 2008 Location: Belfast
The little rig worked good. Jay Bug gave it a beating at Little Rock City.
01-28-2014, 06:03 AM | #17 | |
lol Yes she did, if we can just get her to slow down now . | |
02-01-2014, 06:08 PM | #18 |
Well I got the risers in (half kit) . I don't fell I need them in the front as they are level or just up on the chassis side of the links . The risers are very east to install . Just dropped the skid and removed the links . Wraith 4 Link Skid Risers from DCW I'm going to run the stock truss the first time . Then I will switch to Duuuuuuuude D-mount . That away I can compare the two . Ultralite Delrin D-Mount from DCW It might be hard to tell in the pics . But in the bottom holes I gained 2 to 3 degrees . That will for sure help with the squat factor . Last edited by Badd; 02-01-2014 at 07:31 PM. |
03-10-2014, 07:44 AM | #19 |
Rock Crawler Join Date: Oct 2011 Location: Canada
| Re: Badd's Fusion 1.9 Wraith with SCX10 axles What a great shot. I'm watching this slow progressive build, As I really want to turn my wraith into something useful instead of a 2.2 Monster truck. Will the D-Mount allow you to bring the links ahead (forward) of the axle any more? this may help with squat as well. |
03-10-2014, 02:32 PM | #20 |
I have not added the D-mount yet . The risers took care of the problem . I will use the D-mount on another build I guess .
Badd's Fusion 1.9 Wraith with SCX10 axles - Similar Threads | ||||
Trail Finder 2 and SCX10 FUSION | prime_310 | Scale Videos! | 2 | 07-04-2012 01:33 AM |
Need width of scx10 axles with 650 SLW hubs and/or 750? Pondering wraith vs scx10. | Desert Rc | General Scale Talk | 6 | 06-25-2012 05:28 PM |
