07-03-2014, 08:28 PM | #1 |
Rock Stacker Join Date: Apr 2014 Location: canada
| ci inserts
runnin integy beadlocks 2.2 Sedona white dot tires ...what ci inserts should be going in these tires as they list diff sizes on ci website?
07-03-2014, 09:13 PM | #2 |
RCC Addict Join Date: May 2013 Location: Forrestfield, Western Australia
| Re: ci inserts
In all honest your best bet is email CI or pm Nova's Ark 2 thing you need first ..... 1 .make sure you weigh your rig with as you run it (not down to the last ounce/gram), it's important to finding the right foam 2. be sure of what you want to do with you rig, a slow speed crawler will get a way with a softer foam than a faster basher/U4 style racer Good luck |
07-04-2014, 08:13 PM | #3 |
| Re: ci inserts
im just going to order the 5.ot ones as that's what diam my wheels are mountes lol
07-04-2014, 09:37 PM | #4 |
Newbie Join Date: Dec 2013 Location: Mesa
| Re: ci inserts
I would contact CI before you purchase foams on your own. The customer service that I received was top notch, and I'm very pleased with the product that I purchased. I was asked a few questions that led the customer service rep to suggesting the foams that fit my particular application.
07-05-2014, 07:31 AM | #5 |
RCC Addict Join Date: Aug 2012 Location: The Garage!!!
| Re: ci inserts
5.5 med front/firm rear 5.0 is a little short for those tires! Wheels not as much a issue with height just width of wheels will determine how wide the tire will be...if ya gonna do dual stage? Dueces wild foams work great on my wraith with options to trim ribs to provide forward bite! IMO |
07-05-2014, 10:19 AM | #6 |
| Re: ci inserts
so ur saying go with deuces wild and trim to suit?
07-05-2014, 10:43 AM | #7 |
| Re: ci inserts
I like mine a lot! The dueces wild are for heavier rigs & or faster speeds to keep from tire wrap. The dual stage work great but the heavier/faster ya get the more tire wrap(less control)ya get. If you are goin to be crawling(lower speeds)more & with soft sedonas that you got I would recommend the dual stage foams like 5.5 med front,firm rear with the weight of the(stock) wraith it should be what ya looking for. If planning to go with faster setup than stock or brushless I definitely go with standard DW & cut center two ribs in front for a lil forward bite to grip when you hit slower(crawling)terrain! Plus the DW are waterproof!!! Hope this helps(makes sense)...lol again IMO!
07-05-2014, 10:48 AM | #8 |
| Re: ci inserts |
ci inserts - Similar Threads | ||||
threaded inserts | doublej | Axial Wraith | 4 | 02-08-2012 01:07 AM |
Brass Inserts | losikid | Tools and supplies | 0 | 11-21-2011 03:19 PM |
Inserts? | lvl1 | Tamiya Clod Buster | 2 | 11-13-2005 01:10 PM |
Krock inserts or no inserts | sportracer | Tires and Wheels | 1 | 10-18-2005 11:27 PM |
inserts | firstumustcrawl | General Crawlers | 0 | 03-06-2004 05:11 PM |
