03-09-2013, 04:23 AM | #1 |
Newbie Join Date: Dec 2012 Location: Mt shasta
| Wraith Spur Pinion shootout 32p vs. 48p
What is you opinion on spur pinion combos for my wraiths and my SCX!0. I have researched like mad and even posted on the forum and I'm getting conflicting info. So I'm just trying to run it by people who know. I 'm just out to trail crawl and have fun on home made obsticals and rocks logs forest, maybe at most G6 with some all out running but just to get from challenging zone to challenging zone. little to no jumping or bashing. looking for smooth slow speeds and torque but with some wheel speed when needed. I'm on the Tekin FXR brushed motor ESC combo 35t. for all four of my rigsThree wraiths for my kids and my scx10. I have been steered toward the super shafty Wraith trans. A bit overkill but bomber. It comes with a 56t 32p metal RR spur that i am planning on pairing with an 11t 32p. Is that a good combo? Or is that for going fast and bashing? If don't go with super shafty I will go back to stock with crawler inovations output upgrades. I have crawler inovations traxxis drive shafts for all my rigs as a way to beef up that area but still have a fuse in the drive train it is a cheap and easy replacement. I have a stock SCX10 trans that I will beef up with the CI output kit and Drive shafts. I have no idea what to gear it as. Looking for moderate to cool temps. Can you give me suggestions for where to start experimenting? 1. Wrath trans. a) 32p spur & pinion combo b) 48p spur & pinion combo Thanks much! |
03-09-2013, 05:00 AM | #2 |
| Re: Wraith Spur Pinion shootout 32p vs. 48p |
03-09-2013, 06:11 AM | #3 |
Quarry Creeper Join Date: Dec 2010 Location: Alberta
You should post a 3rd thread on this crap.
03-09-2013, 06:28 AM | #4 |
Rock Crawler Join Date: Oct 2011 Location: Canada
Double post shootout - Posting in one forum, or posting in two?
03-09-2013, 07:34 AM | #5 | |
Rock Stacker Join Date: Feb 2013 Location: Apache Junction
| Re: Wraith Spur Pinion shootout 32p vs. 48p Quote:
Off the top of my head i can't remember the gearing i got last week. I run with a guy who is a very solid wraith crawler here in AZ, Crawler-Dad is his tag name. He is running 60tooth 32 pitch, and a 9tooth 32 pitch. Its giving him a 6.66 ratio. He also uses a 45turn integy motor, which i just picked up and run with a tekin crawler ESC and i love it. The 32's are a bit beefier than the stock so you have to do a bit of mod on the transmission gear cover for it to fit smoothly, using a dremel with a grinder stone cleaned it right up. I know i'm using a 32pitch but can't remember the exact tooth combo, but i'm at a 6.9 gear ratio right now. | |
03-09-2013, 11:26 AM | #6 |
I wanna be Dave Join Date: Jan 2012 Location: CANADA
I am running 32P gears! I love the 56T Spur and 14T pinion right now. I use Traxxas Spur and RR pinion. No mods to my cover! Fits perfect and with my Tekin RS and Redline 13.5T Brushless set up it is great so far!! 2S power is plenty of speed for me!! I tried 3S and wow! I would call my Wraith flipper...lol. |
03-09-2013, 11:46 AM | #7 |
56/14 here to . sometimes i gear up to 20/14 when i feel i want to go alittle faster on my 2100kv motor
03-09-2013, 12:36 PM | #8 | |
03-09-2013, 08:36 PM | #9 |
ok so i'm rocking 48 pitch 87tooth and a 13tooth
03-09-2013, 08:51 PM | #10 | |
I wanna be Dave Join Date: May 2011 Location: Lost in Oregon
32p ...56t spur,14t pinion....your perfect at 4:1 Wicked fast and a hell-of-a lot of fun | |
03-10-2013, 05:33 AM | #11 |
Rock Stacker Join Date: Jan 2012 Location: Vancouver
RR's gear ratio chart was helpful for me: Robinson Racing Products - The Leader in Gears for RC Cars Stock wraith spur and pinion would be 80/20 on 48p I believe, so your at 4:1. I picked up a Traxxas 54t spur and both a 9t and 13t RR pinion giving myself 6:1 and then close to stock with 4.15:1 respectively. For how cheap the gears themselves are, I'd say just pick up a 54t or 56t spur gear and then start messing around with pinion tooth count until you get an idea of what you like torque-wise in conjunction with the wheel speed still available at each gearing choice. |
04-05-2013, 01:52 PM | #12 |
Rock Crawler Join Date: Oct 2011 Location: Vertical Junkie
48P no way.. I hate replacing gears... All the rigs I currently own are upgraded to 32P On the Ash Wraith, I run 14/56 on a Tekin 4.5 3s, 5000mah... Zombie Wraith, 11/56, Tekin 4.5 3s, 5000mah... Mad Skinz Axial JK 14/60, Tekin 7.5 Gen2, 3s 4000 Mad Skinz RC4wd Boyer Truggy Chassis, 12/56, Pro4 4600 3s 4000mah ******** Not one stripped gear Yet!!!!!******** Of course these are all high Kv, high powered, Heavy Rigs... Zombie is 10.4lbs and driven the most.. Heres a few Pics. |
04-05-2013, 02:15 PM | #13 |
I wanna be Dave Join Date: Jan 2009 Location: New Port Richey, FL.
Im still building mine, but im trying a vxl motor and RR 48p 14/93 gears with stock axle gears.
04-05-2013, 02:33 PM | #14 |
Rock Crawler Join Date: Dec 2011 Location: Blacksburg
don't know why people think you have to have 32p. I've been running the RRP 48p 80t steel slipper/spur for atleast 6-8 months with a MMP/Pro4. I run a 17t pinion with no problems. Still have the original top shaft too, But have upgraded to HR steel tranny gears.
04-05-2013, 04:50 PM | #15 | |
Newbie Join Date: Mar 2013 Location: Canada
04-06-2013, 11:19 AM | #16 |
Newbie Join Date: Jan 2012 Location: victoria
I have owned 2 Wraths at this point , both are brushless (tekin 10.5 and 13.5), both have all steel drivelines, and I run stock 48 pitch spurs. (87:14 and 87:20) works great, and if I do break something in the driveline, its most likely gonna be a 4$ spur gear. As opposed to something more substantial, obviously, your driving style , and the terrain your running on is gonna dictate how well the plastic spur will hold up for you.
04-06-2013, 12:54 PM | #17 | |
Thats cause they are steel 48P .. Plastic is what the forum is what the forum was asking I believe. You also cant get a slipper eliminator (Old style AX10 Steel cup) running the Robinson system. Its also way over-priced than a $6 Delrin Spur. If you want it locked, just zip some screws in it... Just saved yourself, $24 | |
04-06-2013, 01:19 PM | #18 | |
08-11-2014, 06:22 PM | #19 | |
Rock Stacker Join Date: May 2014 Location: vancover island Canada
08-11-2014, 09:14 PM | #20 |
Newbie Join Date: Aug 2013 Location: Australia
I have been running my wraith with 48 pitch 87t plastic spur, standard tightened slipper and 17 t pinion. I have a ROK 412 3100 kva and MMP on 3S. I do a mix of slow crawl, trail run, and hill climb on rocks for a fair while now with no issues. I give it heaps without being stupid, the slipper works regularly , but that's what it's there for. Use a little common sense, no problems yet. Love it.
Wraith Spur Pinion shootout 32p vs. 48p - Similar Threads | ||||
Spur pinion Shootout 32p VS. 48p SCX10 | Willy Smellson | Axial SCX-10 | 6 | 03-09-2013 03:12 PM |
32p spur/pinion questions | tbilz | Formula Offroad | 16 | 05-30-2011 07:13 AM |
0.8 metric pitch spur w/pt 32p pinion | Drexcl | General Crawlers | 1 | 01-11-2011 10:43 PM |
Anyone run 32P Pinion/Spur Gears? | MDcrawler72 | Axial SCX-10 | 18 | 05-15-2010 09:38 PM |
