08-03-2014, 07:45 PM | #1 |
Newbie Join Date: Jul 2014 Location: minneaolpis
| Is this a dead steering servo?
I am new to this hobby For my first truck picked up the Wraith and have been loving it! Possibly to the death of my steering servo motor. Not knowing what a dead servo motor behaves or sounds like ... i shot this quick video of my issue. (the sound you hear comes from the steering servo motor) Wraith Steering Servo - YouTube When the horn is hooked up the steering motor makes the same grinding sound you can hear as when i apply the small pressure twist to it unconnected as seen in the video. its like the motor is not 'catching' internally and grinding gears or skipping. You can also see even turning the controller makes the motor "grind". Is this a dead servo motor? If so recommendation for a replacement? I am mostly into trail running with it so far. thanks in advance! ~derek |
08-03-2014, 08:03 PM | #2 |
Pebble Pounder Join Date: Apr 2014 Location: Nevada
My friend its a goner those servos do not hold up long you have to drive real real easy on them. Its def fried and trash. I run a cheap 19$ servo and to date I'm on #3 most people on here will just say buy a titanium gear servo to replace it...do some research they are great but with a stock radio they don't work to their full potential and you have to add stuff like a bec and once you do that all that power in the servo will likely break a steering component. There's a ton of info on here however so you can make your own decision. Sent from my Moto X using Tapatalk |
08-03-2014, 08:18 PM | #3 |
| Re: Is this a dead steering servo?
Thanks for the prompt response! Ok time to do some research on a replacement |
08-03-2014, 09:25 PM | #4 |
I had been posting on another thread and he had the same problems deadbolt build help Sent from my Moto X using Tapatalk |
08-03-2014, 09:39 PM | #5 |
Quarry Creeper Join Date: Aug 2013 Location: Fort Worth
Amain hobbies sells the Solar D772 for $20. High voltage, high torque with ball bearings and metal gears. You will need an external BEC to run this. This is an alternative if you don't want to spend $100+ on a good hitec or savox servo. I run a couple of these and have not had any problems so far.
08-04-2014, 08:10 AM | #6 |
Newbie Join Date: Jun 2014 Location: Hampton
Yea, I bought a wraith a while back and ran into the same problem. I called axial and they sent me a replacement since I had only owned the truck for a week when it went out. The replacement had half the power of the original and also died. So I decided to go ahead and upgrade to a savox 1231. Good servo with plenty of power, but be aware that once you upgrade to a more powerful servo those plastic steering links have to go. They bend and cause the truck to have problems steering.
Is this a dead steering servo? - Similar Threads | ||||
Servo dead | skullking | Electronics | 1 | 02-13-2011 10:21 AM |
Servo dead, which one to get? | McMoron | Losi Micro-Rock Crawler | 11 | 06-20-2010 09:19 PM |
Dead servo | 90SouthCrawlers | Electronics | 8 | 02-02-2009 04:49 PM |
dead servo | lockednloaded | Electronics | 5 | 04-29-2006 11:55 AM |
Servo dead?? | MaxxZilla | Electronics | 0 | 08-22-2005 11:21 PM |
