Thread: What are the best Servo Mount options?
Old 03-10-2015, 05:33 AM   #1
Default What are the best Servo Mount options?
I know there is the VP Pan-hard setup but I'm wondering what other options there are. Looking to eliminate the regular slop from the screws working loose on the stock type on axle setup.
I believe on axle is still preferable for steering compared to the pan-hard?
I have seen the DinkyRC mount which looks promising?
o0wiz0o is offline   Reply With Quote
Old 03-10-2015, 09:43 AM   #2
Default Re: What are the best Servo Mount options?
before I did much research I bought the RC4WD CMS kit and have been very happy. I'm still a rookie at this sport so I haven't noticed the bump steer or other issues that the vetrans complain about. I simply bought it for the looks and have been really happy with the quality of the parts and how its performed.
SynisteR6 is offline   Reply With Quote
Old 03-10-2015, 10:18 AM   #3
Thanks for the input. Looks good. Nice and clean.
Old 03-10-2015, 10:36 AM   #4
Dinky set up is rock solid.
Dostradamas is offline   Reply With Quote
Old 03-10-2015, 10:43 AM   #5
See I like the Dinky....But then I live in a climate where it is Wet and part of me say get that servo up high! But I'm sure I read on axle is better.
Old 03-10-2015, 10:52 AM   #6
I have the VP setup. The rig is still under construction so I cant speak from a performance standpoint. But I have noticed that if you run a low ride height ( I plan to) the articulation is slighly limited on one side when the panhard hits the frame. Shouldnt be too bad. The effect looks minimal.
The main thing with any CMS is to have the panhard bar and draglink as parallel as possible throughout the suspension stroke. This is where people have bumpsteer problems. That said, that Dinky axle mount does look good... And having the servo there means less sprung chassis weight and lower CG than any cms. There's always a trade-off.
DeviledEggs is offline   Reply With Quote
Old 03-10-2015, 10:53 AM   #7
I live in Oregon and it is wet and mossy here as well.
Get that weight low up front.
Axle mount is the most efficient use of servo torque.
Old 03-10-2015, 11:02 AM   #8
Yeah I think the Dinky is winning. I'm waning to function rather than form. The Stock plate method has to go. It's actually all metal now and it still flexes and screws come loose and my servo is not a complete power house....only 277oz.
Saying that looks like the Dinky is as rare as rocking horse poop!
Old 03-10-2015, 11:11 AM   #9
The dinky mount does raise the front link mount points a bit.
It also is steel so it adds some weight with that strength (right where I like it.)
Dlux makes a sweet AR60 mount as well out of carbon fiber.
AR60/Wraith Servo/Truss/Link mount
Old 03-10-2015, 11:13 AM   #10
Post a wanted ad, there are lots out there.
I bet someone has one they would part with.
Plenty of parts hoarders
Old 03-10-2015, 11:17 AM   #11
Being UK based it's hard to get the parts sometimes. Always a nice Customs charge to. :(
Old 03-10-2015, 11:33 AM   #12
Yeah that shipping is a killer I bet.
If money were no object I would bring it to ya if we could meet at the Old Tadcaster and have an oatmeal stout.
Damn $$$
Someday I hope to get on your Island.
Old 03-14-2015, 09:18 PM   #13
I've had the vp cms for over a year. It works great. Yea there is a little bump steer but that's the cost of a cms. I'm running a futaba servo pushing over 500 inoz and that takes care of my steering issues, if any. But it all comes to personal preference.
ynmech is offline   Reply With Quote
Old 03-14-2015, 10:39 PM   #14
Or you could do something a little more direct..
(Not mine. Just liked the idea.)
Sevastra is offline   Reply With Quote
Old 03-14-2015, 11:39 PM   #15
I was going to go with that set up but I could have sworn somewhere on one of the threads that the suicide switch steering was hard on servos? They called it a servo killer, any truth to that?
Revoasian is offline   Reply With Quote
Old 03-14-2015, 11:42 PM   #16
Norton's Avatar
I used that suicide steer setup for awhile, it works pretty good but it is a servo KILLER!
Funny you said that /\ I use Saxox 1230's pretty much in all my rigs and that setup was the only one that killed one.
Norton is offline   Reply With Quote
Old 03-15-2015, 12:35 AM   #17
I don't know about killing servos but that wouldn't steer perfectly right. The arc of rotation on the servo horn would basically increase toe in as you turn. The result would make it so the inside tire never turned as sharp as the outside.
coryshad is offline   Reply With Quote
Old 03-15-2015, 12:40 AM   #18
Bummer deal! Thanks for insight, I too use the Savox 1230 in all my rigs. Hard to beat 500 in. oz. for 80.00 or less.
What are the best Servo Mount options? - Similar Threads
AR60 servo mount options greenjk General Crawlers 5 07-04-2014 11:33 PM
LF T-rex axle servo mount options Dad,Canyoufix? Axial SCX-10 0 04-17-2014 07:02 AM
***Crawler Innovations Engraved Servo Guard-Servo Clamp-Servo Mount GIVEAWAY*** Nova's Ark General Crawlers 106 10-20-2013 02:16 AM
Options to mount bodies? phunkodelic General Scale Talk 14 08-15-2009 12:11 PM
servo mount options w/o clocking links? solomon7 HPI Wheely King 7 07-30-2007 10:31 PM
