Thread: Trans / dig questions
Old 03-25-2015, 10:31 PM   #1
Default Trans / dig questions
I have gotten a vp dig in a trade, complete with servo, etc. I'm thinking of attaching it to an scx tranny, either the stock or the HR I have on my other truck to put in to the wraith.
Anyone know of the vp dig will mate to an HR trans?
Is the dig sturdy enough to deal with occasional brushless bashing?
I have RR trans gears, MIPs, HD diffs, sensored BL 3100kv, 56/10 gearing, pretty tight slipper, etc.
Mainly for crawling but some u4 type Rolling as well...
Turtlejon is offline   Reply With Quote
Old 03-25-2015, 10:40 PM   #2
Default Re: Trans / dig questions
I have a DIG in my 4x4x4 Wraith but I rarely use it since I added rear steer
DrDiff952 is offline   Reply With Quote
Old 03-25-2015, 11:13 PM   #3
Yeah, I'm kinda interested in rear steer as well, but I have this sitting here...
Also I had been running MOA for a while, and I liked how it helped climbing. I have read that it doesn't have the same effect on a wraith, though. Can anyone elaborate on why not?
On the MOA, on super steep climbs letting the back wheels free kept the front end from lifting off of the rock, and the front 2 wheels could pull it, sometimes. Does this not happen on a wraith?
Old 03-27-2015, 07:40 PM   #4
So is the dig sturdy enough to deal with some high speed bashing? I imagine I'd just leave it in 4wd...
Old 03-28-2015, 09:53 AM   #5
I run 2200 3s 60 amp rated packs into a Castle MMP into a first generation ROC 412 3100. The axial case, DIG and internsls haven't had a problem.
Old 04-03-2015, 08:52 AM   #6
Thanks! I have read that they may not be be tough enough for bashing, but this makes me more optimistic!
Any other opinions??
Old 04-03-2015, 11:27 AM   #7
Should be fine! Be sure to clean with alcohol on output & set screws use blue locktite let sit overnight
The dig is a great option for any rig & has same benifits on all including wraith!!! I run 3 vp dig units with one being a wraith setup for crawling.
sic1to is offline   Reply With Quote
Old 04-16-2015, 04:29 PM   #8
So, just to follow up, a VP dig will not bolt up to a HR trans without some dremeling...
Also, if using a standard size servo, it will not fit with a 550 can motor without modifying something, or using a low profile servo...
Old 04-26-2015, 06:37 AM   #9
Oh yes. Make sure you use a sensored brushless motor. Save the sensor less motors for the quad copters
Old 04-26-2015, 03:48 PM   #10
Yeah, pro4hd!!
Trans / dig questions - Similar Threads
R2 dual DIG trans questions tbilz Axial AX-10 Scorpion 3 03-09-2011 05:29 PM
