01-21-2015, 09:01 AM | #1 |
Rock Stacker Join Date: Mar 2014 Location: North Bay
| Holmes BR-XL gearing in a wraith
Good day everyone, i have been trying to find others that are using the holmes hobbies torquemaster br-xl in their wraith that would like to know what other gearing options they have with certain motors. Currently i am using a crawlmaster expert 13 turn with 16/87 gearing and on three cell lipo my motor doesn't even get too hot to touch. I would like some more wheel speed and was wondering if I should get a 4 cell lipo or change my pinion or spur? Please post what motor and gearing you use. Thank you. |
01-21-2015, 09:28 AM | #2 | |
RCC Addict Join Date: Jul 2008 Location: San Diego
| Re: Holmes BR-XL gearing in a wraith Quote:
01-22-2015, 04:03 AM | #3 | |
My wraith is a scale crawling rig and the yeti and my twin hammers are my ultra 4 racers and my slash 4x4 is my basher. I even have a sensored brushless system in my hpi sprint. Thank you though, as i didn't mention that above and i should add i would like to know about using higher voltage batteries with the brxl. | |
01-22-2015, 04:07 AM | #4 |
Just a picture of my wraith |
01-22-2015, 10:18 PM | #5 |
Yep, the Brxl will take 4s perfectly fine! Just plug it in.. But.... Your motor most likely will not. :( it will for a short time.. If you would like to run 4s, I would suggest a HH 16t crawlmaster pro. I'm a HUGE fan of the crawl type HH motor's! I ran a 16t on 4s in my scx for a year, without issue. I only pulled it to switch to a HH Trailmaster BL.. You would be surprised at how Smooth it is for crawling! I have one in my scx for a year now and was running a second in my wraith/Sexo for a good period of time. They both crawled like a brushed motor but could snap a speed on in a instant! (Like 20mph in 2 second's!) Brxl on 4s, yes 13t on 4s, mmmmaybe.. Cool thing is, you could get a 16t crawlmaster pro armature and drop it in ur can. Then enjoy it 4s! :thumbsup: |
01-22-2015, 11:06 PM | #6 |
Quarry Creeper Join Date: Oct 2010 Location: denver
I ran a brxl with a HH 27t for a bit on 4s, the thing ate brushes! But if you pick up the parts just rebuild the motor every 3/4 uses.
01-22-2015, 11:43 PM | #7 | |
The 16t crawlmaster pro, I didn't replace the brushes in it once. Then it got moved to a XR and then passed on. | |
01-23-2015, 11:09 AM | #8 |
What I should have said is you might just destroy the commutator on 4s or higher. I have seen pictures of the back of the motors melt on high voltage systems. That is why I suggested you might want to go brushless. It would be less expensive to run brushless in the long run. If you volt up make sure you gear down. Drop down the pinion 3 teeth.
Last edited by SDheavymetal; 01-27-2015 at 04:27 PM. Reason: spelling................ |
01-27-2015, 04:11 PM | #9 |
Thank you guys, i really appreciate all your feedback i think a pro armature is what I'm gonna do.
01-27-2015, 04:35 PM | #10 |
Rock Stacker Join Date: Dec 2014 Location: South of columbus Indiana
At 5.4 ratio and not getting hot/warm you could definitely add a tooth or 2 and keep an eye on the temp. I run the 16t crawlmaster pro with a 5.6 ratio on 3S. Doesn't even get warm in this weather. I get almost an hour on a 2200mah. I mostly crawling around. faster then I care to "trot" after it on 3S Still enough wheel speed to get up the hills.
Holmes BR-XL gearing in a wraith - Similar Threads | ||||
wraith gearing | wetjet06 | Newbie General | 1 | 01-15-2015 04:07 PM |
Wraith Gearing Need Help? | AJW | Newbie General | 5 | 01-06-2014 04:33 PM |
Gearing For Wraith | Chesebro | Newbie General | 5 | 06-09-2013 12:00 PM |
Wraith gearing help | Kelly H | Axial Wraith | 8 | 06-09-2013 11:18 AM |
Gearing Wraith for crawling | Baisley101 | Axial Wraith | 8 | 03-05-2012 08:23 PM |
