02-09-2015, 04:35 PM | #1 |
Pebble Pounder Join Date: Jan 2014 Location: richmond
| Yeti trailing arms with wraith skid plate
Anyone running yeti trailing arms and rear links on a wraith?
02-09-2015, 04:52 PM | #2 |
| Re: Yeti trailing arms with wraith skid plate
your rear end would be stretched out quite a bit...
02-09-2015, 04:53 PM | #3 |
It will be on a wraithzilla chassis
02-09-2015, 05:06 PM | #4 |
Rock Crawler Join Date: Nov 2010 Location: the 'burgh'
You can do it no problem, it just lengthens the wheel base by 1/2". You will need longer upper links to compensate. |
02-09-2015, 05:19 PM | #5 |
Think the links need a little bit Of trimming to make them move more freely
02-09-2015, 05:27 PM | #6 |
twin hammers arms are .4" shorter. blue monkey makes wraith specific length trailing arms also.
02-09-2015, 06:04 PM | #7 |
I know blue monkey makes them just really expensive. Might look into twin hammer rear links and trailing arms
02-09-2015, 09:28 PM | #8 |
Y-Town Crawlers Join Date: Oct 2005 Location: Not Hesperia
I would go with a wraith or yeti length rear trailing arm before a TH length one. I'm running VP yeti rear lowers and they work great with a little dremel work to the skid. I also had to space the links in slightly at the axle to keep them from binding when I was running stock link mounts.
02-09-2015, 10:11 PM | #9 |
Quarry Creeper Join Date: Dec 2010 Location: Anaheim
run them from the outside last screw on the side of the skid plate so they are straight. everybody I see that throws them quickly on a wraith puts them at an angle from the stock lower link mount. real trailing arms are not meant to run like that. I have 2 linked real prerunners and the trailing arms are straight and I have never built a customer angled trailing arms on any of my trucks. A slight triangulation is okay. Having the trailing arms mounted out wider will also help with the body roll associated with shock on link setups.
02-09-2015, 11:01 PM | #10 |
Yep do the rear screw that holds the skid on to mount them. thats what I did.
02-10-2015, 05:22 AM | #11 |
ok ill check it out today. my wraithzilla should be here today.
08-18-2015, 12:53 PM | #12 |
Rock Stacker Join Date: Mar 2014 Location: North Bay
| Re: Yeti trailing arms with wraith skid plate |
08-18-2015, 04:52 PM | #13 |
Very nice. I love new options and retrofits! What rear uppers are everyone running?
08-18-2015, 05:38 PM | #14 |
Quarry Creeper Join Date: Apr 2014 Location: a land bereft of rocks
Holy wheelbase batman! That looks dope!
08-20-2015, 10:19 AM | #15 |
Rock Stacker Join Date: Apr 2014 Location: Anaheim / Big Bear
Hot racing makes a decent rear aluminum trailing arm for the twin hammers. I remember it coming with different sized spacers and studs so you can customized the length to your liking and it was only 30$
08-20-2015, 07:04 PM | #16 | |
RCC Addict Join Date: Jul 2009 Location: Ontherocks
| Re: Yeti trailing arms with wraith skid plate Quote:
I run TH trailing arms on my wraith, mounted on the last hole on the skid with custom double sheer mounts/sliders. It's worked out great | |
08-21-2015, 01:27 AM | #17 |
Newbie Join Date: Mar 2014 Location: Adrian
I'm running VP Twin Hammers arms on mine, also at the last skid mounting screw but instead of mounting it outside, I notched the skid to be able to put them between skid and frame rail. The stock plastic chassis didn't like the stresses of that setup but my new Dinky RC steel chassis doesn't complain a bit Now I just need the SSD axles. And an HH Puller Pro. And finish the interior. And...... |
08-21-2015, 07:47 AM | #18 | |
08-21-2015, 11:02 AM | #19 |
I tried the inside... Hit the chassis. Sent from my VS986 using Tapatalk |
08-24-2015, 07:47 PM | #20 |
| Re: Yeti trailing arms with wraith skid plate Yep, mine did too. I ended up clipping off the back section of the lower frame rail to make room. I added a vertical riser between upper and lower rail but the stock plastic just wasn't up to the task. The Dinky chassis I picked up has a better design that allows me to run this setup with free range of motion on the arms.
