05-10-2015, 03:21 PM | #21 |
Rock Crawler Join Date: Mar 2013 Location: columbus
| Re: Project khaos continues Well i have some update info for every one. I have had Khaos out to the rocks for 3 weekends now. I have had to make a unwanted change. The Cms is gone after braking 3 left side cvd's i pulled it out. Do to the suspension articulation and the servo horn room in the chaise. there is just not enough room to make it work properly with the high steer hubs. Trust me this is not something I wanted to do. I did put a 12 tooth pinion in the gearing is now 12/54. Im very happy with the drive ability of this rig. Now for some run photos Last edited by greengoblin; 05-10-2015 at 03:26 PM. |
05-10-2015, 03:48 PM | #22 |
Quarry Creeper Join Date: Jun 2014 Location: 36oly
Do you plan to try and get cms back on later?
05-10-2015, 07:25 PM | #23 |
| Re: Project khaos continues Yes part of why i took it of is do to the body and how low it sits on the truck. So when it comes time for a new body it will have larger fender openings. I put all the parts in storage with my other back up mount so it don't get lost. I just cant bring my self to hack up this body. Last edited by greengoblin; 05-10-2015 at 07:28 PM. |
05-10-2015, 07:48 PM | #24 |
Any idea what exactly caused the breakage? I have the same cms mount on my little wraith and I've been impressed with how well it actually works. How much total suspension travel does your truck have now?
05-14-2015, 06:36 PM | #25 | |
| Re: Project khaos continues Quote:
05-14-2015, 10:24 PM | #26 |
I have my cms and axle pushed a little farther back and am using stock wraith shocks lowered all the way. I've been lucky somehow I have almost no bumpsteer. I'm also using some berg knuckles that match stock scx knuckles, but I do have some play in my chubs that causes a little on my pass side tho.
09-24-2015, 05:51 PM | #27 |
| Re: Project khaos continues I have added some new thing to khaos. Love this rig. I swaped the strc cvds out for a axial set do to brakage. I have added front and rear lights intgy aluminum axle trusses, white knuckle rc 7 millimeter aluminum links. Im runing it on 3s get about 2.5hr out of a 5000mah pack |
Project khaos continues - Similar Threads | ||||
Project KHAOS | Deadpool | Axial Wraith | 46 | 04-19-2015 11:20 PM |
