04-27-2015, 08:24 PM | #1 |
Newbie Join Date: Apr 2015 Location: Southwest Missouri
| MIP Driveshafts for Spawn
Can anyone tell me if the AX10 driveshafts work for the Spawn like Harley did on his PS? I know the shafts are a little different and wanted to make sure before I ordered them, Thanks in advance!
04-27-2015, 09:41 PM | #2 |
Rock Crawler Join Date: Feb 2011 Location: Spur, TX
| Re: MIP Driveshafts for Spawn
Not sure about the AX10 shafts, but MIP makes a kit specifically for the Wraith that covers all versions. MIP Spline CVD™ Center Drive Kit, Axial Wraith #11116 |
04-27-2015, 09:47 PM | #3 | |
Newbie Join Date: Apr 2015 Location: Kentucky
| Re: MIP Driveshafts for Spawn Quote:
04-28-2015, 02:00 AM | #4 |
RCC Addict Join Date: May 2013 Location: Forrestfield, Western Australia
The AX10 shafts work fine, there's no difference in any of the Wraiths in trans output or axle input. Yes Grigz you remember correctly, it's in Harleys guide that the MIP Wraith shaft set uses the stock Axial screw pins which have only the 1.5mm hex, the AX10 shaft set uses the bigger Traxxas size pins with the 2mm hex (just have to remember to order along with the shafts) Last edited by altd896; 04-28-2015 at 02:13 AM. |
04-28-2015, 08:45 AM | #5 |
Awesome! Thanks for the info!
04-28-2015, 08:46 AM | #6 |
RCC Addict Join Date: Aug 2013 Location: Missoula
The Wratih set has 2 longer outputs to help clear the spur gear/skid. I have never stripped a 1.5mm pin, just use a quality driver.
04-28-2015, 09:01 AM | #7 |
Quarry Creeper Join Date: Dec 2010 Location: Anaheim
When you upgrade to 6mm outputs on the trans you have to go with an mip end that uses the bigger pin also.
04-28-2015, 12:41 PM | #8 |
| Re: MIP Driveshafts for Spawn This. I don't even loctite my pins. Just snug them up with a good driver and check before/after every run. I rarely find a loose one.
MIP Driveshafts for Spawn - Similar Threads | ||||
MIP Driveshafts | Rcdood | Axial AX10 2nd-gen | 6 | 03-28-2015 01:13 AM |
MIP driveshafts | Mudman02 | Newbie General | 4 | 03-20-2015 07:06 PM |
MIP Driveshafts | CamposZac96x | Axial SCX-10 | 9 | 01-09-2013 05:02 PM |
