04-28-2015, 07:17 PM | #1 |
Quarry Creeper Join Date: Mar 2014 Location: San Antonio
| AX10 Deadbolt turned into a Wraith
I picked my AX10 Deadbolt up about a year ago it was my first crawler. It went through a fair amount of changes over that time as I experimented with my new found hobby. I really enjoyed it but as with most things I own I can never just leave well enough alone. Which brings me to The most recent change and why I'm now posting in here. The swap to a Wraith chassis. Here's a few pics from then to now. AX10 Chassis And Wraith Chassis . These were some pics from yesterday on its first shake down run. Last edited by VTHokie; 04-28-2015 at 07:24 PM. |
04-28-2015, 08:12 PM | #2 |
Pebble Pounder Join Date: Dec 2012 Location: Vancouver
| Re: AX10 Deadbolt turned into a Wraith
Nice! I did the same thing to my Ridgecrest when I lost interest in it. The Wraith is a much more versatile platform. |
04-29-2015, 01:16 PM | #3 |
Rock Stacker Join Date: Mar 2010 Location: 934543
This is what my son did with his recently, we bought a Spawn transmission and, using a AE-5....
04-29-2015, 03:42 PM | #4 |
Yeah not really a hard swap. I got the chassis on eBay and changed everything over. My only hiccup was thinking the AX10 transmission would work only to find out it wouldnt. So I bought a Wraith transmission parts tree, the large bearing, hot racing lower one piece steel gear and the Robinson racing mid gear. Also changed over to a 32 pitch setup for the spur and pinion while I had everything apart. I'm really happy with how it turned out. Last edited by VTHokie; 05-15-2015 at 08:23 PM. |
04-30-2015, 07:43 AM | #5 |
I was lazy and just bought a new wraith spawn transmission from ebay...now i am in the process of trying to make my own links for 2 wraiths and then also a set for an scx10
05-15-2015, 03:43 AM | #6 |
Newbie Join Date: Nov 2008 Location: uk
Nice. I have ax10 and scx10. Tempted to buy the Wraith, but maybe I should convert the ax10. How difficult is the conversion? How much does it cost, vs buying a used Wraith? Lovely Truck u have there! Thanks |
05-15-2015, 06:47 AM | #7 |
It wasn't difficult at all just swap everything over to the Wraith chassis. The Wraith chassis was $80 and transmission $40. That was all I changed. I don't think you can find a used Wraith that cheap.
05-15-2015, 07:08 PM | #8 |
Look on ebay or rcrecycler for wraith part outs. Changing over your ax10 to a wraith is easy. I luckily found a wraith cage with panels from a buddy building up a tuber. This is my list when I did the conversion: skid trans case (Use your ax10 internals) robinson racing solid one piece trans gear (only if your not using the dig) the grub screws to hold the lower links to the skid longer wires for the motor |
05-15-2015, 08:13 PM | #9 |
That's pretty much what I did, bought the wraith trans parts tree for $8. I got the Hot Racing one piece lower gear. You'll need the large bearing for the lower gear as well. AXA1243 Axial bearing 15x24x4mm AX80051 Axial dig transmission case WRA38X Hot Racing Steel Diff Locker Gear RPP Hobby parts out brand new RTR as well and you could pick up the Wraith Spawn trans that has the new dual slipper and 32 pitch gears for about $45. Use the "email me when available" option to know as soon as they have one. http://www.rpphobby.com/product_p/syws6.htm Last edited by VTHokie; 05-15-2015 at 08:21 PM. |
AX10 Deadbolt turned into a Wraith - Similar Threads | ||||
wraith vs ax10 deadbolt vs sxc10 | nerby149 | Newbie General | 13 | 01-16-2015 06:45 PM |
Axial Ax10 Deadbolt and AE-5 | Geck0Jeep | Axial AX10 2nd-gen | 2 | 10-01-2014 08:54 AM |
Axial AX10 Deadbolt | Lentsnh2012 | General Crawlers | 4 | 10-29-2013 12:10 PM |
Rylands new AX10 Deadbolt | jason | Videos! | 0 | 10-25-2013 11:33 AM |
