05-16-2015, 04:19 AM | #1 |
Rock Crawler Join Date: Jul 2013 Location: Kansas City
| Rear bearing carrier is being ground down by hex
ok so i noticed that my wraith has a lot of axle slop. After looking i noticed the shafts are going to deep into the locker and allowing the hex to grind away the bearing carrier. I think that the problem is this: I have beef tubes inthe axles plus a locker up F.I. locker. I am thinking that grinding down the axle shafts to go thru the beef tubes also has nothing to stop it now from sliding back & forth. I have had this set up for over a year and just noticed this lastnight I am gonna try to tear it apart today.
05-16-2015, 06:26 AM | #2 |
| Re: Rear bearing carrier is being ground down by hex
So after taking it apart everything seems to be good. So I'm gonna lok-title the axle shaft tang into the fi spool. Unless somebody thinks that is a bad idea? Edit: i have found the issue, it is in the removal of the shoulder on the shaft to allow it to pass thru the beef tube. In doing this there is not enough material there to stop the shaft sliding into the fi spool , so the fix is a new spool with set screws or ditch the beef tubes? Last edited by realsickclown; 05-16-2015 at 06:40 AM. |
05-16-2015, 09:15 AM | #3 |
I wanna be Dave Join Date: May 2011 Location: Lost in Oregon
Maybe a pic or two ??? Would help to understand this better....
05-16-2015, 09:27 AM | #4 |
it is not necessary to completely remove the shoulder on the axle shaft....just enough to fit thru the beef tube...i would get another pair of axles and remove just enough of the shoulder to fit thru the beef tubes..I did mine this way and have no issues like you are having.
Rear bearing carrier is being ground down by hex - Similar Threads | ||||
Pinion carrier bearing issues | arnesto | RC4WD Trail Finder 2 | 21 | 02-14-2017 08:58 AM |
Such a thing as a 1/10 scale carrier bearing? | summervillecrawler | South Carolina | 12 | 01-10-2013 02:06 PM |
Who Can make a carrier bearing???? | balln | General Scale Talk | 9 | 07-22-2011 09:33 AM |
N E 1 where I can find a 1.3mm ground or machined hex driver ? | Joat | Tools, and Procedures | 1 | 02-22-2009 07:30 AM |
