08-04-2015, 09:04 PM | #21 |
Newbie Join Date: Jan 2015 Location: Oklahoma
| Re: Problem Child
Eric the hoods you have linked look different unless vengeance has done some trimming? The V2 wedge looks a lot like it but looks like it has a grill
08-04-2015, 09:19 PM | #22 |
I joined the Band! Join Date: Dec 2014 Location: Earth
| Re: Problem Child To me it looks like the V2 Wedge cut straight across the front to remove the grill area. I never noticed a gril-less hood from Dinky, but there may have been one that got discontinued before I started looking at their site.
08-04-2015, 09:22 PM | #23 |
| Re: Problem Child |
08-04-2015, 09:28 PM | #24 |
Quarry Creeper Join Date: Apr 2010 Location: Earth
| Re: Problem Child
Wish I could be more help. I bought 1 of each V1, V2, V3 over a year ago and none have mesh. They only differed by size of the cowl. Bringing the pain since 1968 |
08-05-2015, 01:20 AM | #25 |
Quarry Creeper Join Date: Jul 2014 Location: North Florida.
| Re: Problem Child
Steel mesh and cut Mudslingers on a ProLine AX10 tube frame. Ahh I miss that rig.. |
08-05-2015, 08:32 AM | #26 |
| Re: Problem Child |
08-05-2015, 10:51 PM | #27 |
| Re: Problem Child
Ok so today I was reminded WHY I love beadlock rims so much. Had to glue on my 2.8 SandPaws to the rims for FOFF mode. Know what I found out? I still hate glueing tires. That was however after I duct taped the inside of the tires so they didn't expand so much when under full throttle. I also swapped out my 13t pinion for a 15t pinion for more top-end as the low-end was crazy torquey. Is torquey even a word??? And installed the hood pin system. I need to get some thin steel wire to connect the body pins to the washers however. Lastly will be mounting the fuel cell and swapping out the purple countersunk washers and shock spacers with matching lime-green ones. Bringing the pain since 1968 Last edited by Vengeance; 08-05-2015 at 11:01 PM. |
08-07-2015, 01:26 PM | #28 |
| Re: Problem Child
Reworked the hood pins today for little more scale realisim. Later I will replace the black wire on the hood clips with small gauge steel wire like our winches use. For now though I used black servo wires and ca'd the ends. Not sure how long they will hold up but they seem to handle me pulling the pins out. The black washers are from Axial rims I had lying around and ARE bolted onto the hood. The pins themselves are the old stand-by Traxxas battery pins but I had to shave them flat on two sides for the hardware holding the washers on to clear. Now that she is pretty much finished I will most likely use her for trail and crawling//KOH driving. I never planned on putting a winch on the front but will most likely do so and remount the Gearhead 6-Shooter LED array currently on the front bumper. Bringing the pain since 1968 Last edited by Vengeance; 08-07-2015 at 01:35 PM. |
10-01-2015, 08:34 PM | #29 |
| Re: Problem Child
Quick update... Other than installing the race harness this truck is done. I took her to the ocean a couple weeks ago and was very pleased how well the rig did in the sand without paddles. Here are a few shots... Bringing the pain since 1968 |
10-01-2015, 09:03 PM | #30 |
| Re: Problem Child |
10-02-2015, 07:43 AM | #31 |
Quarry Creeper Join Date: Aug 2014 Location: Indy
| Re: Problem Child
I dig the build man. How do you like the BGR towers? I am about to order a set myself.
10-02-2015, 09:30 AM | #32 | |
| Re: Problem Child Quote:
For hill climb I can drop the rig pretty low. For more articulation I can raise it up. The BGR parts are pricey but worth it if they suit your needs. The Mud Slinger XL tires have really surprised me by their versatility. They handle deep sand well, rock climbing, etc... The only other tire I would contemplate using on the rig is the Ottsix Voodoo U4. Bringing the pain since 1968 Last edited by Vengeance; 10-02-2015 at 09:33 AM. | |
10-02-2015, 06:20 PM | #33 |
| Re: Problem Child
I'm so jealous of your shock towers. Can you run a battery plate with the front? I've got a lot of shit under the hood. |
10-02-2015, 06:27 PM | #34 | |
Bringing the pain since 1968 | |
10-02-2015, 06:32 PM | #35 |
| Re: Problem Child
Cool thanks
10-02-2015, 06:43 PM | #36 |
| Re: Problem Child |
10-03-2015, 07:58 AM | #37 |
| Re: Problem Child
Thanks for the photos. That answers my questions.
10-03-2015, 09:42 AM | #38 |
| Re: Problem Child |
10-03-2015, 08:17 PM | #39 |
| Re: Problem Child
I really like those mud slingers. I've been wanting to get a set for a long time. Are you running wider cans on those beadlocks? They look great with those tires.
10-03-2015, 11:27 PM | #40 | |
Problem Child - Similar Threads | ||||
how to keep 20month old child in wagon? | PEDEcrawlerguy | Chit Chat | 10 | 06-29-2012 11:34 AM |
I am a child that smokes and cusses. | Nlee111 | Chit Chat | 21 | 05-31-2007 11:42 AM |
Child labor | Cloak | Chit Chat | 10 | 12-20-2006 01:27 PM |
Project: Problem Child | mrwonderful | Tamiya TLT Crawlers | 12 | 04-09-2005 05:48 PM |
