Thread: servo question
Old 11-01-2015, 05:14 PM   #1
Default servo question
I'm setting up my wraith for u4 racing and want to upgrade my servo. Keeping an eye on expenses as well. Any suggestions on a good reliable servo for u4?
Cork is offline   Reply With Quote
Old 11-01-2015, 07:06 PM   #2
Default Re: servo question
Solar Servo D772 High Voltage 0.17sec@7.4v 64g Digital Metal Gear
it runs acceptably at 6v
low cost.. decent life use for a throw away
The D772 runs at it's full potential when fed 7.4v
Sooo
either use a external bec set @ 7.4v
or use a decent esc that offers an internal bec at no less then 6v
My HH BR/XL's internal 6v bec seems to be enough.
tho' that will be circumvented in favor of using an external CCbec set at 7.4v
6v turns my 1/6 scale Wraith build acceptably
TacoCrawler is offline   Reply With Quote
Old 11-01-2015, 07:25 PM   #3
Sooo
Thanks for the info. I think I need something a little more than throw away. I need something that can withstand u4 racing. I don't know if you would use the same servo that you would for a crawler.
Old 11-01-2015, 07:42 PM   #4
Norton's Avatar
Savox 1230, Hitec 7950 or 7980!
Norton is offline   Reply With Quote
Old 11-01-2015, 08:05 PM   #5
I like the Hitec 7954sh. It's 403oz/in at 7.4 volts for around $80 shipped on eBay. It has a really quick transit time also. .12 I believe.
SCREAMER is offline   Reply With Quote
Old 11-01-2015, 08:38 PM   #6
I had bad luck with all kinds of plastic cased servos. Never stripped gears, I was splitting the front cases and breaking mounting ears off.
Switched to a savox 1283 with a full metal case and haven't had an issue since.
Had the Holmes servo been out when I was in the market I would have gone that route. Protek 170t is also well respected, although closer to $200.
maslin is offline   Reply With Quote
Old 11-01-2015, 09:14 PM   #7
I use the 7990th and its held up pretty good. I've landed on the front hard enough to bresk an aluminum servo are and didn't mess up the servo.
68_f100 is offline   Reply With Quote
Old 11-01-2015, 11:22 PM   #8
Savox 1230, Best Bang for your buck ! (500 0z/in baby) !
XtrmTJ is offline   Reply With Quote
Old 11-02-2015, 06:57 AM   #9
I did the 1283. I cracked 5 cases and had 3 gear sets fail in every other nice servo I tried. Goggle the 1283 and look at the gear setup. It's big compared. I even had a guy that "hates with a passion savox" now running the 1283 in his fast rigs bc of the strength.
AWraith build is offline   Reply With Quote
Old 11-02-2015, 08:05 AM   #10
Thanks for all the input!
Old 11-05-2015, 07:00 PM   #11
+1 on the Savox 1283SG. Graduated from the 1256TG in my 1/8 stuff to the 1283SG and never looked back. So naturally I put one in my Wraith as well
WT's Pauly is offline   Reply With Quote
servo question - Similar Threads
Servo Question CDN_Crippler RC4WD Trail Finder 2 6 10-27-2012 10:18 PM
hitec servo glitching and a servo horn question m1009cucv Electronics 5 08-18-2012 11:22 AM
2 servo question rcdriver199 Axial Wraith 7 01-19-2012 08:08 AM
servo question badnuz General Crawlers 7 01-09-2010 12:46 AM
servo question Wicked_Jester Electronics 4 06-11-2006 04:35 PM
