03-12-2016, 02:05 PM | #1 |
Quarry Creeper Join Date: Dec 2013 Location: NoVa
| Pro4HD mounting ?
I'm putting together a new Wraith from scrap. When trying to mount the trans with a Pro4HD, the motor can hits one of the link mounts before it can tighten down. Is this common? & What is the best mounting solution? Cutting down the mount or shimming the trans higher? Anyone else see this issue before or Did I do it wrong? CG3 |
03-12-2016, 02:31 PM | #2 |
Quarry Creeper Join Date: Dec 2015 Location: United States
| Re: Pro4HD mounting ?
Yes it's common and you didn't do anything wrong. The Pro4 HD is a 62.5mm long 550 and the Wraith was designed for a 540. You may have to cut the link mount down some and shim the transmission to keep from having to do too much of either one. EDIT: updated to correct specs on motor length Last edited by Soldat Vaillant; 03-12-2016 at 06:07 PM. |
03-12-2016, 05:42 PM | #3 |
Not sure the difference between that motor and mine, if there is any... I'm running a 550 brushed Traxxas motor in my wraith. It hits the link mount. Just used a dremel bit in my cordless drill and sanded the link mount down a bit on one side. It's a tight fit but clears it without raising the tranny.
Pro4HD mounting ? - Similar Threads | ||||
bad pro4hd? | Alexander_0_1 | Electronics | 1 | 04-28-2015 11:13 AM |
