06-07-2016, 11:27 PM | #1 |
Rock Crawler Join Date: Dec 2007 Location: MERICA!
| axle housings
kinda been thinkin about getting metal axle housing for the wraith. which ones should i get? does the aluminum get stuck or hung up more than the the stock plastic? thanks.
06-08-2016, 08:10 AM | #2 |
Rock Stacker Join Date: Oct 2015 Location: Kingston, WA
| Re: axle housings |
06-08-2016, 08:19 AM | #3 |
Newbie Join Date: Mar 2016 Location: SAN DIEGO
| Re: axle housings
The skid plates mount up right? Sent from my SM-G930P using Tapatalk |
06-08-2016, 08:57 AM | #4 |
| Re: axle housings
Yes. It's a long horizontal bolt next that goes through the housing and the small screw on the bottom. I've seen guys use a bevel drill bit and enlarge hole on the bottom, then use a bevel screw so it's flush against the skid Wraith/RidgeCrest axle skids is an example of what it looks like. |
06-08-2016, 04:14 PM | #5 |
Quarry Creeper Join Date: Mar 2015 Location: Woodland
| Re: axle housings
i run the ssd diamond housing, Love how it looks, I think it hangs up a little more since its not hard plastic, but I have not had any issues with it. That skid will make you hang up more than an aluminum axle housing, it will just keep em pretty. However the advantage to running an aluminum housing is mainly for higher speed brush-less systems and scale appeal. I have a rig also on plastic housing, love it, works great after a year, to upgrade it, i will run a Dlux modified housing when the stock one dies.
06-08-2016, 04:25 PM | #6 |
| Re: axle housings
im running beef tubes at the moment but considering the vanquish housings v2 (not the curries) due to there round edges just like a stock plastic housing maybe those will be less of a hang up.
06-08-2016, 04:44 PM | #7 |
| Re: axle housings
actually i just added all the stuff up for the v2 axle housing and it came out to be $150! thats for the housing, truss and a diff cover. might as well get a currie f9 for the same price. idk haha choices choices
06-08-2016, 06:14 PM | #8 |
| Re: axle housings
Dlux big bearing housing with steel beef tubes is less than half the cost of an aluminum housing. The housing is plastic so it slides over obstacles nicely and the steel beef tubes add some weight and are far less likely to strip the threads than an aluminum housing. I smooth my housings bottom half so they are much less likely to hang up. Cheap and effective are the names of my game. |
06-08-2016, 06:38 PM | #9 | |
Rock Crawler Join Date: Aug 2015 Location: Big Island
| Re: axle housings Quote:
This one is getting a hole so it's about time to flip it and put it on the back, another bonus of running the plastic housings. | |
06-08-2016, 07:08 PM | #10 |
| Re: axle housings I only smooth the edges around the grub screw in the tube and the sides of the housing next to the diff cover. I don't take any meat away from the wear areas, that is for the rocks to do. My crawler has 2 month old housings in it now that are almost due for replacement. Time for 7" tires I guess. |
06-08-2016, 08:50 PM | #11 |
Quarry Creeper Join Date: Apr 2016 Location: Canada, Ottawa/Gatineau
| Re: axle housings
Or just the stock plastic housing with the Beef Tubes is plenty good unless you run big power, then step it up to the modded Dlux big bearing plastic housing.
06-10-2016, 09:26 PM | #12 |
| Re: axle housings
Thanks for all the feedback guys!
06-12-2016, 10:22 AM | #13 |
Rock Stacker Join Date: Oct 2012 Location: Yakima
| Re: axle housings
I have a vp aluminum housing in the front of my sporty, it's going in the parts pile for a plastic big bearing Dlux housing... Sent from my iPhone using Tapatalk |
axle housings - Similar Threads | ||||
VP axle housings | Quartermaster | Axial Wraith | 3 | 12-20-2011 06:51 PM |
Axle Housings | TC09mini | Axial AX-10 Scorpion | 5 | 09-25-2011 08:54 PM |
New axle housings? | low_range | Tamiya CR-01 | 9 | 01-02-2011 11:01 AM |
