12-11-2017, 02:42 AM | #1 |
Newbie Join Date: Jan 2016 Location: Spain
| More power needed!
Hi guys!!! I’ve stock gears, and a Holmes 27t brushed and I need more power, more speed!! I will try with a 3s lipo but I guess it will not be enough... I would like a brushless combo as much waterproof as it could be... and It should allows me to crawl a little... What are your suggestions?? Thank you so much! |
12-11-2017, 05:05 AM | #2 |
Rock Crawler Join Date: Mar 2016 Location: Zagreb, Croatia
| Re: More power needed!
I'd go with 3s and a 550 can fiirst... wp and sensored is mighty expensive stuff. |
12-11-2017, 05:58 AM | #3 |
RCC Addict Join Date: Apr 2009 Location: LA
The Hobbywing wp-860 $27 ESC will let you run up to 4s lipo, but make sure your motor can handle the voltage first: http://www.hobbywing.com/mobile/good...er_attr=5426.0 |
12-11-2017, 06:56 AM | #4 | ||
| Re: More power needed! Quote:
12-11-2017, 07:22 AM | #5 |
Castle Mamba X and Tekin ROC412 3100kv or Holmes Puller Pro 3500kv. You won't find a better brushless combo IMHO. |
12-11-2017, 07:43 AM | #6 |
Traxxas 21t Titan 550, or Holmes 550; both run about $20.
12-11-2017, 07:54 AM | #7 |
| Re: More power needed! |
12-11-2017, 11:39 AM | #8 |
Nothing against the Titan or HH motors, just throwing more options out there... Electrifly S600 is a 19t 550 can and the T600 is a 22t 550, either costs ~$13. I've got an S600 on the way for my own Wraith that will be run on 3s, I had previously been running 4s on a 3400kv sensored brushless and decided to go back to brushed after I had an ESC failure. It was pretty fun in a straight line with 4 paddles on it, but was honestly too fast for the way the car handled being locked at both ends. It wasn't getting used as often as I'd hoped, so I think it will actually be more enjoyable and get used more often on a sensible brushed setup. I did try my wp860 and 4s with a well used Titan 12t and it died very quickly. I think that the 19t (or 21t-22t) 550 brushed on 3s should fulfill any need for speed without outrunning what the Wraith's chassis is comfortable with.
12-11-2017, 01:33 PM | #9 |
^ good to know, 550 brushed cans aren't that easy to find!
12-17-2017, 09:02 AM | #10 |
Pebble Pounder Join Date: Jan 2017 Location: Maine
MambaX and the 2280kv Castle Slate motor on 3s works great in mine so far. Plenty of power, long run times and not too bad price wise.
12-18-2017, 07:20 AM | #11 |
Hi guys!! Problem with Mamba is that if I buy to US I need to pay around 70 $ for ESC and motor in the customs... Do you know any cheap place to buy it in Europe or Canada?? Thank you! |
12-18-2017, 07:28 AM | #12 |
12-18-2017, 10:36 AM | #13 | |
12-18-2017, 12:10 PM | #14 |
Just be aware that you will have to solder on your own leads, and the motor's shaft will need a flat spot ground into it for your pinion's set screw on the S600. If that's not up your alley, Redcat has a 19t 550 that is ready to go for a couple bucks more BS701-007. The Redcat motor is the only one of the bunch that DOES NOT have a "flux ring" on the outside of the can. I'm not sure what kind of performance differences to expect from different types of magnets, but supposedly the HH and Electrifly motors use better magnets than the Traxxas and Redcat motors, and all but the HH motors use bushings for the shaft to ride on, where the HH uses a bearing at one end. I went with the S600 not just due to cost, but also because their performance specs were readily available.
12-19-2017, 01:52 AM | #15 | |
Can you show us how you did that "flat spot"?? Any pics or something?? Thank you so so so much!!! | |
12-19-2017, 11:03 AM | #16 |
Sorry, no pictures. It will be obvious what needs to be done when you see the S600 motor shaft side by side with your existing motor. You just need to use a grinder/dremel/file/etc to make the shaft go from looking like "o" to looking like "D" when viewed straight on. All you're doing is giving the pinion's set screw a flat spot to sit on. If you use power tools to do this, take your time so as not to get the motor too hot. It's also worth wrapping the motor in masking tape or a rag before you start, so the metal shavings don't go into the motor.
12-19-2017, 03:26 PM | #17 | |
Understood!! Thank you so much!! Enviado desde mi iPhone utilizando Tapatalk | |
12-23-2017, 04:42 PM | #18 |
One more question... i will run 3s lipos... I’ve the Spawn rtr... Do I need an external BEC??? Why?? I just have read about Becs and I absolutely don’t know anything about it!! Enviado desde mi iPhone utilizando Tapatalk |
12-23-2017, 06:04 PM | #19 | |
RCC Addict Join Date: Nov 2014 Location: Nowhere
Now that being said, people are running the Hobbywing WP1080 brushed ESC using the built in BEC and are having good results, if you want both a good replacement ESC and integrated BEC. | |
12-23-2017, 07:33 PM | #20 |
I wanna be Dave Join Date: Apr 2015 Location: Roseville, Ca
If your going to run a 550 can, you will need to trim some of the rear upper link mount for it to fit. Just fyi.
More power needed! - Similar Threads | ||||
Losi Lipo Works On Flight Power/Thunder Power Balance plate?? | fa1rch1ld | Electronics | 0 | 01-18-2010 11:46 PM |
Determining needed power supply amps/wattage | Egnix | Electronics | 3 | 01-08-2009 08:57 AM |
