01-11-2018, 06:27 AM | #1 |
Newbie Join Date: May 2012 Location: canada, quebec
| What pinion should i use?
Im going to put a traxxas 3500kv in my wraith and i was wondering what pinion should i use whit my 80t spur. Thanks. |
01-11-2018, 09:24 AM | #2 |
| Re: What pinion should i use?
That motor isnt sensored so it will cog at slow speed/ startup... That being said, you can mitigate the cogging to a certain degree by gearing lower...use a pinion around 13t 48p which gives you 6.15:1. I would go no higher than 15t as that gives you a 5:1 ratio on your wraith. I have found the sweet spot gearing for my rigs to be between 5:1 & 6:1
01-11-2018, 02:44 PM | #3 |
Its a wraith whit paddle tire. Its more of a basher wraith.
01-11-2018, 06:08 PM | #4 | |
Newbie Join Date: Apr 2017 Location: El Dorado
| Re: What pinion should i use? Quote:
I concur. I have a bomber with a Roc 412 3100KV. 19T pinion 64T spur. The car was simply to fast for me to crawl with. The kid blew out 2 caps on an Rs8 gen2 ESC. Replaced ESC with a RS8 gen 3 and installed 2 speed tranny. Car was still to fast. I finally replaced my pinion with a 12T and this thing is incredible now! ~5:1 Sent from my iPhone using Tapatalk | |
01-11-2018, 06:20 PM | #5 | |
RCC Addict Join Date: Nov 2016 Location: 1972 born Christian, Chinese.
Also I would like to take this opportunity, to say Sorry for I was wrong posted the irrelevant posts just now. I am so Sorry to all of you here, please forgive me. | |
01-11-2018, 07:00 PM | #6 |
Quarry Creeper Join Date: Dec 2016 Location: Cawston, British Columbia, Canada
You might want to consider switching to 32P from the 48P you currently have. About 60T spur and 11T pinion, 5.45:1. Don't know if the 60T spur is too big in diameter or not. I prefer to stay at 12T or above for 32P pinion gears.
What pinion should i use? - Similar Threads | ||||
Help what pinion to use | Jared430 | Axial Yeti | 2 | 11-29-2016 07:33 PM |
Helical ring and pinion gears sets with an offset pinion? | Calderwood | General Crawlers | 6 | 09-14-2013 09:06 PM |
Pinion | SDheavymetal | Axial XR10 | 2 | 07-06-2013 01:41 PM |
New pinion | barshots | Redcat Crawlers | 10 | 11-18-2010 09:13 PM |
55T 20 pinion or 45T 14 pinion | GP40X | Electronics | 0 | 11-10-2009 10:46 PM |
