04-29-2018, 07:52 PM | #21 |
| Re: Skrappy |
05-05-2018, 12:34 PM | #22 |
| Re: Skrappy
Well finished SKRAPPY up and quite a success! Let’s review....... Brand new Wraith cage and skid assembled with a team KNK hex screw set. Links are stock lowers and Alloy uppers. Shocks are from RC4WD and are internally sprung. Axles are stock Axial , with some rear VP clamping lockouts, front has new GPM chubs , knuckles and tie rod . Fast Eddie bearings if needed were used throughout. Motor is a Tekin 17.5 sensored, running through a MMP. Motor plate is a HotRacing with an aluminum spur. Servo is a new JX30kg waterproof running at 7v through a castle 10a external bec, the receiver uses a bypass so the stock red wire remains uncut. I did use stock lexan body panels, and interior. The roof and hood were cut and fit from aluminum , while the inner fenders, hood hinges and fuel cell were 3D printed . After wiring , binding and setting up the bec and MMP with castle link,I had the 4channel Tx/Rx set. I dropped a set of Ruptures onto the race line beadlocks. Hang up and Drive |
05-17-2018, 01:36 PM | #23 |
Rock Crawler Join Date: May 2016 Location: SoWIs
| Re: Skrappy
I found the same front fender files & modded to fit a 4000mah 3S battery, I just need to print & test. A while back I modded the same battery tray you found. I moved the battery up & back a bit, wider strap holes too. Interested? |
05-17-2018, 03:23 PM | #24 | |
| Re: Skrappy Quote:
Sure post em up ! Hang up and Drive | |
05-17-2018, 03:58 PM | #25 |
| Re: Skrappy
I can upload the untested files and update them later. I have a glass bed coming Friday so no prints til then. I might mod the rear with an extra lip near the front since it doesn't quite reach the cage upright.
