Thread: 1.9 wraith stock tire/wheel question
Old 04-20-2019, 10:20 AM   #1
Default 1.9 wraith stock tire/wheel question
Has anyone pulled the stock tires off of the wheels on the 1.9 wraith and found out if they are a normal bead or a glue on only?
I'm looking at one my shop has in stock and I can't quite tell. Like the bomber stock tires are only glue on so if you want to put on a set of bead locks you had to buy a set of tires as well ($50+ extra cost)
terrible is offline   Reply With Quote
Old 04-20-2019, 11:55 AM   #2
Default Re: 1.9 wraith stock tire/wheel question
I have had the R35 compound Trail Grapplers mounted up on a couple different sets of beadlocks.
Col_Sanders is offline   Reply With Quote
Old 04-20-2019, 02:03 PM   #3
The RTR comes with the S30 compound and there is no mention of the bead in the axial info.
Old 04-22-2019, 07:37 PM   #4
I used a heat gun to remove mine from the stock wheels and the bead looked good and they mounted up with out problems.
Sent from my LM-V405 using Tapatalk
ajunlimited is offline   Reply With Quote
Old 04-22-2019, 08:24 PM   #5
The tire on Axial's page looks to have a normal 1.9 bead
altd896 is offline   Reply With Quote
