Thread: 1.9 steering servo
Old 07-01-2019, 04:58 PM   #1
Default 1.9 steering servo
What is everyone running for a steering servo on the 109 Wraiths? I picked up one of the 25KG servos, but it was so tall the servo arm contacted the panhard bar. I ended up mounting the servo from the top and used a Baja Ray servo arm to clear everything.
Mounting the servo from the top presented a problem because the electronics box would no longer go on because Axial decided that form > function and it's more important for the electronics box to look like an engine than actually be functional. I had to design and 3D print a new box cover. While I was at it I gave myself 10mm more room on the inside to stuff the wiring for my BEC bypass harness. Not my best print, but it works. I still despise that the screws are on the bottom instead of somewhere actually convenient.
GA Dawg is offline   Reply With Quote
Old 08-27-2019, 09:12 PM   #2
Default Re: 1.9 steering servo
That is a nice fix. I agree with you on the function vs looks on the front end. Does anyone know which servos are short enough to drop in without doing this mod?
Psycho-Savvy is offline   Reply With Quote
Old 10-01-2019, 07:49 PM   #3
I have run the Eco 120t from a main and am now using the Protek 370 tlb with no problems
sgtlt is offline   Reply With Quote
1.9 steering servo - Similar Threads
Steering Servo/Dig Servo Questions YJJPWrangler Electronics 5 02-02-2011 10:59 PM
Mamba max, 11.1 1350 mil 25c, 5955tg steering servo, 5645mg dig servo BEAU Electronics 5 01-21-2009 02:36 PM
