09-22-2010, 08:21 AM | #21 |
Rock Stacker Join Date: Oct 2009 Location: Boston
I been considering using g-made Zero 104mm shocks. Not really expensive and have had luck with them in the past. $45 for all 4 |
09-22-2010, 08:32 AM | #22 |
RCC Addict Join Date: Sep 2005 Location: Tempe, AZ
So far I really have liked the kit shocks the only thing I think is pretty stupid is that if you want metal collers and caps it's almost $50...you should be able to buy a whole set of shocks for that. For just over that I can buy 8 Big Bore's
09-22-2010, 11:19 AM | #23 |
RCC Addict Join Date: Jul 2009 Location: Farmington, NM
09-22-2010, 12:22 PM | #24 | |
Rock Crawler Join Date: Nov 2006 Location: Albuquerque
| This worked for me. Mine were not leaking at the shaft but they did leak where the shaft assembly screwed into the body. I wrapped teflon tape around the leakers and they stopped. Quote:
Otherwise, love the shocks! | |
09-26-2010, 08:27 PM | #25 |
RCC Addict Join Date: Feb 2006 Location: ccxc
caps leaked like crazy here......and the bladder kept dislodging........I just threw on teflon tape and I'll see how it goes. Plastic caps suuuuuuuuuuuck
09-27-2010, 12:33 AM | #26 |
Rock Stacker Join Date: Jan 2009 Location: tacna
| o-ring I went to home depot and spent $1.76 on 10 o-rings size #7 they fit pefect no leaks and i was able to tightin the cap dwn all the way. Last edited by jchavezfam1022; 09-27-2010 at 07:22 AM. |
09-27-2010, 01:56 AM | #27 |
Pebble Pounder Join Date: Jul 2010 Location: Seattle
09-27-2010, 07:32 PM | #28 |
where do the new orings go? in place of the bladder? Does the bldder do anything worthwhile? I cant stop the caps from leaking and bladders from falling in(yes they are pressed in)
09-27-2010, 11:55 PM | #29 |
Pebble Pounder Join Date: Mar 2008 Location: K-ville
duratrax evader's best choice
09-28-2010, 03:10 AM | #30 |
| O-ring you dont need the bladder just pull it out and install the o-ring all the way into the shock cap.i think it works better with out the bladders.
