11-30-2010, 08:09 AM | #1 |
Rock Stacker Join Date: Oct 2009 Location: ky
| New build Suggestions
Ok I know everyone has there own suggestion just finished kit last night..So I need a little help going to run stock chassis and learn it first what I have now Bwd links like limiteds (2) fxr 45 handwounds 4pk What I need to order next hitec 7955 or? What front wheels and hubs rear wheels and hubs? lockouts? chubs? steering knuckles? Change steering link? shock springs |
11-30-2010, 08:25 AM | #2 | |
11-30-2010, 08:57 AM | #3 |
Hey thanks I really like your crawler as well...On the servo ok, I run one of them in my truggy, so I will get another.You say losi gold, what are they off of or dimensions? so order dh2 for front with 350? and 600 and slv for rear? I see some running 460 fornt? is that on dh2 or dh? whats the difference, going to order today so need make sure get right stuff,also just order direct or from?
11-30-2010, 09:01 AM | #4 |
Itty nailed it with one exception. DH II's you will want 460 hub, original DH's you want to use 335 hub as the 460 hub will put your tire mounted wheelbase well over 11" |
11-30-2010, 11:46 AM | #5 |
I pretty much agree with these guys, the 600's are just a little wide in the rear IMO, I'm gonna swap mine for .475's. You might grab a set of weights also, I don't run any yet with DH/SLW but need to add a little to try out as most are adding weight with that combo. You'll want to do something about the stock tranny bearings also, VP cases and the 9mm mod to the motor plate is what I'd suggest right now. It's the most important mod to the truck IMO and the only must do right off, VP knuckles are the next after that. Nothing else has to be done right away. |
11-30-2010, 12:10 PM | #6 |
Sometimes, I make things. Join Date: May 2009 Location: Mt. Upton
Best suggestion-don't get attached to your money cause you will be spending a lot of it I recommend the VP gear cases, even w/ the stock motor plate and bearings in my roller it made a huge diffrence in how smooth the drivetrain rotates. Mine is still a roller tho so I can't be too helpfull other than that. All the VP goodies are a good idea if you can part w/ the loot, the rear lockouts take out most all the rear wheel slop and the chubs and knuckles are nice options too but remember you won't be able to use stock wheels w/ them. |
11-30-2010, 01:34 PM | #7 |
what width rear wheels do I need
12-01-2010, 10:18 AM | #8 |
what width for rear wheels 1??
12-01-2010, 10:32 AM | #9 |
Rock Crawler Join Date: Jan 2009 Location: crawlorado
1" are great for the rear...i run dh 2's with one ring removed (.960) in the front and 1" slw v1 remachined in the rear 460 front and 475's out back...works awesome....and yes vp bushings or 9mm bearings in the plate are a must...
12-01-2010, 10:35 AM | #10 |
If you get DH's front I'd go with 1" rear, with DH2's you could go either.
12-01-2010, 12:11 PM | #11 |
Quarry Creeper Join Date: May 2007 Location: home
12-01-2010, 06:14 PM | #12 |
well decided 4pk and (2)fxr, they will be here tommorow, so now trying to figure the wiring out and and setup for the 4pk jeez...ordering wheels ommorow
12-01-2010, 06:42 PM | #13 |
| Check out Harley's 4pk thread in the electronics section. It has everything you need to get setup, it even has a step by step programming video. |
12-02-2010, 10:50 AM | #14 |
Thanks guys, Now just waiting on the brown truck to drop off a package
