03-28-2011, 11:40 PM | #1 |
Rock Stacker Join Date: Mar 2011 Location: Manitowoc
| motors and esc on my truck now i have the Novak M2 Digital 3S ESC/Dual Terra Claw Brushed Motors but i really dont like them set up is their anything else that would be better then that |
03-28-2011, 11:43 PM | #2 |
Yep, there's quite a few options...actually probably too many to list. The first thing we need to know is what type of Transmitter you are using.
03-28-2011, 11:48 PM | #3 |
i am using the futaba 4PL-2.4G
03-29-2011, 12:02 AM | #4 |
Rock Crawler Join Date: Apr 2006 Location: Hartland, MI
| Perfect. Ditch the M2 and get dual ESCs. Most guys run Tekin FXRs or Castle Mamba Micro Pros, but there are other options for you. The 4PL will mix the two ESCs. You will want to check the serial number to see if it has the firmware upgrade or not. If it starts with 010 it is the old version, if 012 its the new one and won't need to be upgraded.
03-29-2011, 12:18 AM | #5 |
I just got it like a week ago so I am still trying to figure it out and I would like to get new motors to but I dont know which ones because I just finished my truck two days ago and went to try it out and the rear motor was smoking a little
03-29-2011, 12:25 AM | #6 |
And I have never used a dual esc before
03-29-2011, 12:31 AM | #7 |
the number is B012 and other numbers but i dont remeber the rest if thats the serial number
03-29-2011, 12:34 AM | #8 | |
I'd check under Harley's build thread. Look around, all sorts of info on wiring dual ESCs, the big thing is that your radio can handle it! | |
03-29-2011, 12:47 AM | #9 |
Yeah definitely just spend some time reading and figuring out what's what. Informed decisions are always better around here...and you'll only make a good informed decision if you inform yourself...otherwise you're operating on nothing but opinions. Opinions can be good, but if you're into this hobby you won't mind spending some time reading through some build threads and reviews to see what works and what doesn't. Harley's thread is a great place to start since he does a good job explaining things. |
03-29-2011, 08:39 AM | #10 |
Alright thanks but were can I get the vanquish wheel weights from I can't find them any were online
03-29-2011, 09:02 AM | #11 |
03-29-2011, 09:25 AM | #12 |
Here's the VP links Silver: http://www.vanquishproducts.com/revo...eight-se8.html Brass: http://www.vanquishproducts.com/6-ca...eight-se6.html |
03-29-2011, 09:31 AM | #13 |
like i cant find a websit that has them
03-29-2011, 11:11 AM | #14 |
Dude, seriously.......... http://www.rpphobby.com/product_p/vp...weight-se6.htm http://www.rpphobby.com/product_p/vps01065.htm Both in stock |
03-29-2011, 11:20 AM | #15 |
Check the first post of this thread for all the important links to everything you need to know about your radio: Futaba 4PL Setup, Tips, Tricks & Help Read this thread about the other needs of your XR10: Harley's Complete XR10 Guide |
03-29-2011, 12:33 PM | #16 | |
It is Tuesday... | |
03-29-2011, 01:25 PM | #17 |
Rock Crawler Join Date: Aug 2008 Location: Wine Country
| Give the ESC a chance, I run it on a berg and it works great, start by changing out the motors. try some Holmes 45t. Only thing I had to do to get it to run better was the firmware update from Novak. |
03-29-2011, 03:08 PM | #18 |
But see my front wheels turn forward and my rear wheels turn backwards so it won't move anf I dont know whats wrong
03-29-2011, 04:03 PM | #19 |
| You need to do sone serious research man. Just search and read. I have VERY detailed videos explaining how to wire stuff up. It doesn't just apply to dual ESC's. You just need to flip the wires on the rear motor.
03-29-2011, 04:13 PM | #20 |
Quarry Creeper Join Date: Jan 2011 Location: 801
I run the dual FX-R escs and love the way they go together and are set up, but beware on retarded questions because you will be set aflame for them The search button is your best friend here since there is a VAST amount of information already covered from what most people need help on
