10-12-2011, 08:19 PM | #21 |
RCC Addict Join Date: Jun 2008 Location: Amish Buggy PA
Get this thing on the rocks I would like to see your findings on how well it works. The no skid idea seems cool but not sure how it will effect the truck while on course.
10-12-2011, 08:21 PM | #22 |
Rock Crawler Join Date: Jan 2011 Location: Hartford City, Indiana
10-12-2011, 08:31 PM | #23 |
| I put it on my small pile of rock after work tonight before I mocked up the new rear lowers, and it worked realy well.................. In fact, I'm positive I'm not going back to a skid. When I told EGRESSor about what I was doing, he simply said, "You will like it" and, I do!!!!!!!!!!!!!!!!!!!!!!! I plan on taking the weight off the wheels and getting it on the ends of the axles below center, this thing should be crazy good then. |
10-12-2011, 09:56 PM | #24 |
Pebble Pounder Join Date: Mar 2011 Location: citrus heights
wow, just plain awesome! i'm a huge fan of your hot rod inspired topper. |
10-12-2011, 11:48 PM | #25 | |
Quarry Creeper Join Date: Dec 2010 Location: Earth
Anyways back on track- the crawler looks good. Would definitely help breakover! | |
10-13-2011, 12:28 AM | #26 |
I wanna be Dave Join Date: Oct 2007 Location: 801
Looks pretty wild steve!!! |
10-13-2011, 01:14 AM | #27 |
Try to Bend it Join Date: Aug 2009 Location: Perth Australia
10-13-2011, 04:55 AM | #28 |
10-13-2011, 11:40 PM | #29 |
10-13-2011, 11:57 PM | #30 |
True but you might go there for a beer from time to time. That is unless you are a tea toatler
10-15-2011, 06:48 PM | #31 |
OK! Thanks to Erik DLux I got mt titanium links and link sliders today, and bent them up tonight. Been working on this thing the last 2 days hot and heavy for a comp tomorrow in Indianapolis. Made some new skins too so I thought I'd post some pics before I scratch it all up I took it out in the yard and ran it over the rock pile before it got dark. I am happy as hell with the way it works. Other than getting the weights off the wheels and on the knuckles there's not much room for improvement. Unless I start tinkering again................................. Weight with battery RTR 5.88 lbs. |
10-15-2011, 09:15 PM | #32 |
RCC Addict Join Date: Apr 2009 Location: Behind the wheel
HELL YEAH STEAVE!!!!! Thats sweeet! cant wait to see how it does in the morning. |
10-16-2011, 05:57 PM | #33 |
And.........?????? How did It go? |
10-16-2011, 06:29 PM | #34 |
Well, it performed pretty well, but I had some hanging up on what is left of a skid. So............I'm re-doing the chassis. I really want more clearance at the skid. The skid clearance was 3 1/4" and the high part of the rear links were 4". I'm gonna tweak the bends on the rear lowers, and maybe go with a super short skid that is just long enough to hook the links on. What ever I do, I'll have to make the frame taller to get the topper a little higher to keep it legal. I'll have all day tomorrow to think about it at work, so it's hard telling what direction this thing will take tomorrow night. I forgot to mention that I need to learn how to drive. It was a really cool place to crawl. Was outside between 4 Wheel Parts store and an old Jiffy Lube, on a strip of rock for guys to test out their 1.1 Rigs. Some massive rock but a good mix, and some holes to get swallowed up in. I had a great ride down to Indy with Handicrawler. He had a little trouble with his Losi toward the end of the comp, so we shared my rig and he showed me how good it would handle with a good driver behind the radio!!!!! Last edited by TJ Steve; 10-17-2011 at 05:00 AM. |
10-17-2011, 05:04 AM | #35 |
This is more how I want my lower links setting, with a super short skid plate. Marc has it right! |
11-04-2011, 03:50 AM | #36 |
Rock Stacker Join Date: Nov 2010 Location: Silicon Valley
Christian fixed the rear upper links on his tuber like the red line in the picture. The wider fixing point gives more stability for the rear. I also use this concept for my bodyless Tracer. Awesome chassis - steve |
11-04-2011, 04:41 AM | #37 |
Thanks Toy Master, but that frame is history now. I decided to go with a super short skid for a little more lower frame support, and to get the front and rear lower link ends more even. It's working much better for me. |
11-04-2011, 09:13 AM | #38 |
Quarry Creeper Join Date: Jan 2011 Location: westminster
| You will gain alot of stability if you out board the uppers !! also the rear lower work much better on the inside of the fronts if you want it skidless works awsome on the breakovers also helps to have the uppers mounted verticaly above the lowers with the rear 1 hole higher than the front to drive the front down on climbing
