01-19-2012, 01:28 PM | #1 |
Pebble Pounder Join Date: Nov 2011 Location: Yucca Valley
| whick knuckle weights??
Im getting ready to purchase some knuckle weights and need some feedback.Which knuckle weights would you prefer using, VP or D-lux?? Why? Im looking for any responses I can get here, whether you have had experience with both or just one or even none....
01-19-2012, 01:48 PM | #2 |
| Re: whick knuckle weights??
Both do the same thing, and both are very popular. Neither work with stock knuckles though. So if you don't have VP knuckles, You will need to do Kieren's homemade kncukle wieghts. Knuckle weights How To |
01-19-2012, 01:59 PM | #3 |
Thanks TSK. Im glad someone of your reputation jumped up to the plate!!! Your builds are always right on and posts very informative. I do have the VP knuckles but the Dlux thread said some grinding may be needed to fit the VP incision knuckles so i was kicking it around on the forum before i hit the add to cart button!!!
01-19-2012, 02:14 PM | #4 |
Rock Crawler Join Date: Oct 2010 Location: Switzerland
I`ve got 1 set of D Lux and one set of VP. They fit both like a glove to the XR10 VP knuckles no grinding needed. VP mainweight: Are havier and all screws are metric, and fixed with 4 screws from the backside Dlux mainweight Are lighter then the VP ones, but you can add the Steel Ring around it, and the are fixed with 1 setscrew on the Knuckle. |
01-19-2012, 03:35 PM | #5 |
Rock Crawler Join Date: Oct 2010 Location: triad
i was fixin' to say, i've got the deluxe weights on my vp knuckles and they fit like a glove. No grinding.
01-19-2012, 07:17 PM | #6 | |
| Re: whick knuckle weights?? Quote:
I think the grinding some people mention is to actually do a small drill point (like a countersink) into the VP knuckle to allow the D Lux's set screw to seat deeper. I personally have D Lux weights on my tuner, have NOT modded my knuckles, and have NOT had the knuckle weight come loose. The set screw doesar the finish a bit, so if that kind of thing bOthers you, the VP set might be the way to go. However some D Lux users have drilled and tapped a couple holes on the back side to allow use of button head screw to clamp the main weight on similar to the VP's mounting style. | |
01-19-2012, 07:54 PM | #7 |
I'd recommend the VP weights since I had a good experience with my set. I've got their weights o my 8* knuckles on my berg now. I know the VP weights have been out of stock for a little while now, but you should see them back soon enough |
01-19-2012, 08:32 PM | #8 | |
Just my opinion rather than " the word on the streets" kinda thing. Lots of post and good replys as well as always active on the forum. Ya, funny as soon as I went to the VP site meaning to do some real bidnis and clicked the button.....It said outta stock!!!! the Dlux weights are out as well!!! guess I gotta get in line Quote:
01-19-2012, 08:36 PM | #9 |
Got my tires and wheels today!!! only had time to get one battery through them though. Tommorow will tell the reat of the story but nice work so far so good!! I will get to some posting tommorow or this weekend. I have to get some pics and a little more test time!! Thanks for the quick handling and delivery |
01-19-2012, 08:39 PM | #10 |
Try to Bend it Join Date: Aug 2009 Location: Perth Australia
Either of the above are great products and they both do the same job. I have seen another style getting around but I can't remember the name. the top of the ring is slotted and they clamp to the knuckle similarly to a clamping servo horn. They may fit the stock knuckles but I can not be sure. |
01-19-2012, 08:43 PM | #11 | |
Here they are. Axial XR10 Stock Knuckle / Axle Weights | |
01-19-2012, 09:30 PM | #12 |
Thanks fellas. It looks like the cytthroat weights only fit stock shaped knuckles. Looks like im still waiting on VP. tick tock tick tock goes the VP clock. Im currently waiting on red VP upper link mounts as well, on the other hand i just got a set of wheels 2 days after I ordered them. Special thanks to EAST COST RC
01-20-2012, 12:06 AM | #13 |
RCC Addict Join Date: Jan 2008 Location: Apple Valley,CA
Hey matt there is a set of d-lux weights in the for sale section. Better hurry http://www.rccrawler.com/forum/sale/...eed-money.html |
01-20-2012, 07:54 AM | #14 |
Got em!!!! Also ordered some add on rings this morning so i can start playing around with the weight. Whew that was a close one. Thanks TSC and IllEagle for getting that back to me so quickly. They sure wouldnt have lasted long. Im finally nearing the end of my build purchases!!! Im.sure lots of tweaking on this or that lies ahead but at least i wont have to keep going by the usps office two or three times a week!!! Really looking forward to these next couple of comps. Still have alot of names to learn(real names that is).
01-20-2012, 08:03 AM | #15 |
Newbie Join Date: Nov 2011 Location: Allentown,Pa
I'm looking for weights too. I got ST Racing knuckles and was wondering what weights would fit them and are they basically the same as stock? Thanks!
01-20-2012, 08:40 AM | #16 | |
Rock Crawler Join Date: Aug 2010 Location: Socal
I'm glad you got them because I was looking for a reason to hold off buying another set just this second. Even though its enevitable that I will be buying another set to finish my AX10 / XR10 sporty build here in the next month or so. Quote:
01-20-2012, 08:44 AM | #17 |
| Re: whick knuckle weights?? |
01-20-2012, 10:19 AM | #18 | |
But to be sure, post a pic of your knuckles. If they look llike the HT's with the silly "Y" shaped double shear arm, you'd be outta luck. If they look pretty much like the stock plastic one, you are good to go. If they do look like the HR one's just make your own weights. 001Hulk, I'm glad you scored them. I PM'd you as soon as I saw them | |
01-20-2012, 10:35 AM | #19 |
These are the knuckle so the are just stock replacement. Thanks for the help!!!! Last edited by coilwolf; 01-20-2012 at 10:37 AM. |
01-20-2012, 10:43 AM | #20 |
whick knuckle weights?? - Similar Threads | ||||
Knuckle Weights vs. Wheel Weights | Harvo | Tires and Wheels | 34 | 11-16-2011 01:15 PM |
Knuckle weights? | EvilTwin v2 | Scale Comp Rules | 21 | 09-09-2011 06:21 PM |
Knuckle Weights | Erik D_lux | EnRoute Berg | 238 | 06-03-2011 01:42 PM |
