02-28-2012, 09:47 AM | #1 |
Pebble Pounder Join Date: Feb 2012 Location: wooster
| Chaotic Chassis/Links...Shocks/springs? to use?
Thinking about pulling the trigger and getting the chaotic chassis and links. Any recommendations for shocks? Springs? Or any other setups worth looking at? I thought this setup was good because the chassis and links go hand in hand, no bending or wasting links...since I've never done that before... Thanks! |
02-28-2012, 09:59 AM | #2 |
I wanna be Dave Join Date: Dec 2008 Location: anderson
| Re: Chaotic Chassis/Links...Shocks/springs? to use?
i run losi 4 in on mine with the front limited to 3 1/2 4 in. in the rear losi golds all around i no some of the other teamates run the big bores an you will like it for it is very easy to set on an it works really well . if you get it an have any queston just ask one of us an we will be happy to help you mark an nick are really cool guys to deal with an will help you out as well Last edited by slowride1; 02-28-2012 at 10:02 AM. |
02-28-2012, 10:04 AM | #3 |
RCC Addict Join Date: Jan 2009 Location: O.C
Check out a few of these builds. They'res a lot of info in here for setups and tuning advice. The chassis and links make a great starting platform and the performance is fantastic. I highly recommend pulling the trigger on them together. http://www.rccrawler.com/forum/axial...ro-%2A%2A.html Chaotic crawlers Lw special chassis ~Chaotic Special Bodiless....Pro Edition~ *NOW IN CARBON FIBER* Paystin's Chaotic Crawlers XR10 |
02-28-2012, 10:09 AM | #4 |
Newbie Join Date: Jan 2012 Location: Suonenjoki
I have got on my Berg with chaotic chassis the Traxxas BigBore 3,5" shock with mini-t springs and it works great. |
02-28-2012, 10:29 AM | #5 | |
| Re: Chaotic Chassis/Links...Shocks/springs? to use? Quote:
02-28-2012, 10:32 AM | #6 |
the soft one . sorry i dont no the part number if you look threw some of the build treads im sure someone tells what it is Last edited by slowride1; 02-28-2012 at 10:36 AM. |
02-28-2012, 10:34 AM | #7 |
Thanks everyone!!!
02-28-2012, 10:50 AM | #8 |
Rock Crawler Join Date: Sep 2009 Location: Orangevale
I had 47 in big bores on mine and could not get it to work like I though it should I went to a 3.5 Big bore and it started to work much better I would go that way.
02-28-2012, 12:35 PM | #9 |
I've read about using scx10 shocks, which appeals more because of the price. Now does anyone know if I gotta get different spring cups to run mini t springs? I saw JeepinDoug makes some machined derlin cups, do I NEED them? Or can I run these on stock scx10 shocks?... http://www.ebay.com/itm/Losi-2-75-Sp...item2a17d512db Last edited by OhioCrawler; 02-28-2012 at 12:47 PM. |
02-28-2012, 12:48 PM | #10 |
I wanna be Dave Join Date: Jan 2009 Location: laying low
I use 3.5" big bores in the front with mini-t springs and 4" in the rear with mini-t springs(4" are external limited) big bores are cheaper then the scx10 shocks I bought...Alum scx10's cost almost $70 IIRC...and they take some work to get them not to leak and extra parts to make them long enough. |
02-28-2012, 12:55 PM | #11 |
Quarry Creeper Join Date: Feb 2012 Location: dryden
hit up Wickedwolferc in the vendor section if you decide to go to the traxxas big bores he sells the modified shock caps, you can pick up the shocks caps and Jeepindougs spring retainers for the mini t springs all in one place.
02-28-2012, 04:16 PM | #12 | |
Quarry Creeper Join Date: Sep 2011 Location: On PayPal trying to make funds appear.
i just got these and they are really sick recommended | |
02-28-2012, 04:56 PM | #13 |
Rock Stacker Join Date: Nov 2011 Location: Cheyenne
i also have one... awesome chassis, heres my build, i use traxxas 4" in the rear and 3.5" up front, both with the shock cap mod and losi mini springs... My Chaotic Crawler Build |
02-29-2012, 12:59 AM | #14 |
Its a HARDKNOCKZ Life... Join Date: Feb 2011 Location: Southern Kali...
I personally run the Big Bores and they work well. I know Chris aka paystin runs the SCX plastic bodied shocks and likes em. LCCs work good but you'll wanna limit em down a little to get your ride height a little lower. I also have a set of stock XR shocks that Ive been playin with and they also work good. The trick is getting on the rocks and figuring out what works for YOUR rig. We all have different setups so what might work well for one might not for another. The Wicked Wolf caps ARE cool but they'll make your Big Bores a little too long unless you limit em. I personally don't see the need for inverted shocks and think the trade off for the tiny bit lower cg isn't worth the inconsistent shock travel. Again...thats just my opinion. J.D. |
02-29-2012, 04:33 AM | #15 | |
So what's the trick for the stock Xr shocks? ...of coarse I have a set of those haha I mean around $40 for big bores, about $45 in mods...ouch, not including the chassis and links | |
02-29-2012, 08:04 AM | #16 |
| Re: Chaotic Chassis/Links...Shocks/springs? to use? lol your building a comp rig man, just wait till the ouchies start, $85 is just a drop in the bucket when the bug bites ya bad. And beleive me it WILL!!!!!
02-29-2012, 08:19 AM | #17 | |
I just like to get my ducks in a row before I start buying stuff. | |
02-29-2012, 08:45 AM | #18 |
lol i've spent over 2 grand since feb 7th
02-29-2012, 08:56 AM | #19 |
Quarry Creeper Join Date: Nov 2011 Location: Thunder Bay, Ontario
Do the stock axial shocks/springs not work well??
02-29-2012, 09:03 AM | #20 | |
But these things are going to depend on your rig. Things like total running weight, bias, link position, drive style, terrain etc etc etc all have an affect on suspension. I've been tuning a suspension bug for about a month and finally got her dialed out...I hope. Point is...I tried running a similar setup to Paystin while we were out practicing and what worked for his rig, didn't do so well on mine. That being said...any of the Chaotic builds that Chris listed ARE good jumping off points and you can contact any one of the Chaotic drivers and we'll be happy to help ya anyway we can. J.D. | |
Chaotic Chassis/Links...Shocks/springs? to use? - Similar Threads | ||||
Chaotic Links on Viper Chassis? | armycrawler101st | Axial XR10 | 25 | 09-23-2011 02:46 PM |
