03-04-2012, 02:09 PM | #1 |
Pebble Pounder Join Date: Oct 2006 Location: Montreal
| Loose lower links at chassis?
The rod ends seem to be a little too thin for the area they connect to at the chassis so they slop around a bit.. Is everyone's like this? It seems to be the same problem at the axles and even the lower shock mounts, but the plastic at those points will crush and take up the slack if you tighten the screws a little extra..
03-04-2012, 02:17 PM | #2 |
| Re: Loose lower links at chassis?
You will get that with some things if the parts are molded or formed. If the parts are machined and are made to hold tight tolerances, you can expect allot better fit. Both the XR's we have did have a touch of this at the skid, not enough to really worry about. A thin washer on one side of the rod end in the pocket will help.
03-04-2012, 04:45 PM | #3 |
on mine where the lowers attached to the skid i just added some thing washers as well to get rid of the slop
03-05-2012, 02:28 AM | #4 |
Its a HARDKNOCKZ Life... Join Date: Feb 2011 Location: Southern Kali...
| Re: Loose lower links at chassis? |
03-05-2012, 08:29 AM | #5 |
Loose is better than binding. |
03-05-2012, 12:44 PM | #6 |
Quarry Creeper Join Date: Jun 2010 Location: Ireland
Shim for the win.
Loose lower links at chassis? - Similar Threads | ||||
anyone raise the lower links and cut the chassis | Jcplante | Redcat Crawlers | 8 | 08-26-2011 02:00 PM |
Question about moving lower links inside chassis | g_green | Axial AX-10 Scorpion | 4 | 01-23-2010 04:10 PM |
