03-19-2012, 05:24 PM | #1 |
Quarry Creeper Join Date: Apr 2010 Location: The basement of the science building.
| Steering Tie Rod
What is the length of a stock steering tie rod for the XR10? I want to use an aftermarket replacement that is bent at both ends on my Berg V1 with Vanquish knuckles. Center rod end hole to hole length on mine is about 160mm. Rod length (without threaded rod for rod ends) is 130mm.
03-19-2012, 05:37 PM | #2 |
| Re: Steering Tie Rod
Stock XR steering setup is a 3 piece design and is shorter in total length due to the included ackerman of the stock knuckles. You probably are asking about a Chaotic Crawlers Ti bent tierod. You should PM him and I'm sure he can get you the measurement you need. |
03-19-2012, 06:04 PM | #3 | |
| Re: Steering Tie Rod Quote:
03-19-2012, 06:45 PM | #4 |
Rock Stacker Join Date: Oct 2005 Location: North side
| Re: Steering Tie Rod |
Steering Tie Rod - Similar Threads | ||||
delrin for tie-rod and steering linkage??? | yjdavid | Axial AX-10 Scorpion | 5 | 11-21-2009 11:54 PM |
KK high clearance tie-rod vs. CKRC OTA tie-rod vs. ?? | BigB_117 | EnRoute Berg | 64 | 07-06-2009 11:20 PM |
Non Tie-Rod Steering? | Robb | General Crawlers | 26 | 06-04-2008 02:14 PM |
