03-30-2012, 10:18 AM | #1 |
Rock Stacker Join Date: Nov 2007 Location: Arnold,Crawlifornia
| Whats gonna break first?
Im really thinking about pulling the trigger on getting a xr10 roller, im just curious on whats going to need to be upgraded. Im more of a backyard basher but do hit the occasional comp, so I would rather build stout.
03-30-2012, 10:32 AM | #2 |
Pebble Pounder Join Date: Jul 2010 Location: malta
| Re: Whats gonna break first? |
03-30-2012, 11:14 AM | #3 |
Rock Crawler Join Date: Jan 2011 Location: New Brunswick
Yes, do some searching... but what is your budget like? If you're just shooting for a backyard basher, things like larger bearings in the motor plate, RC4WD gears, and some bronze bushings (VP, Traxxas) will get you going with good reliability. Project uber cheap and effective XR This is a good read. |
03-30-2012, 11:28 AM | #4 |
RCC Addict Join Date: Nov 2011 Location: Surrey,BC- Canada
All u need to start is the motor plates and trans plate.then when u can afford get some gears.my buddy has been running his like that for two months now. we run r trucks hard and use them almost every day on my test pile. |
03-30-2012, 08:35 PM | #5 |
Thanks next pay check, might bye the xr10 roller. Any recomandaton on esc.
03-30-2012, 08:38 PM | #6 |
Rock Crawler Join Date: Oct 2011 Location: smithville
Tekin fxr's or brxl
03-30-2012, 08:38 PM | #7 |
Rock Crawler Join Date: Oct 2009 Location: Michigan
03-31-2012, 05:06 AM | #8 |
Try to Bend it Join Date: Aug 2009 Location: Perth Australia
So you still have not,bothered to read Harley's guide. Fxr's are ok but you will be better served by a pair of castle creations mcro side winders. Check out Harley's guide look at a few build threads and go from there. You will be able,to answer all of your own questions with just a little research.
03-31-2012, 05:17 AM | #9 | |
| Re: Whats gonna break first? Quote:
03-31-2012, 08:59 AM | #10 |
I wanna be Dave Join Date: May 2011 Location: Lost in Oregon
Ah...he's trying to build up his post count.... Really though, I read this forum for two months before I purchased my XR...then promptly started to upgrade the thing....but if you build it stock and do it well, it will last a long time. A buddy of mine ran stock for a loooong time...and he wasn't nice to it... Change out the steering link right away though...can't believe they actually did it that way...total garbage Have fun. |
03-31-2012, 09:11 AM | #11 | |
Exactly posts Any ways thanks for the replys. Except the australian they all seem too be pissed off, maybe its the shitty beer. Just kidding, im not a stranger to the search bar or harleys sticky. Quote:
03-31-2012, 09:57 AM | #12 |
Then why ask questions that you ought to already know the answers to. Btw mine was not the only reply suggesting that you ought to search. Have fun with xr10 if you decide to buy it |
03-31-2012, 10:09 AM | #13 |
03-31-2012, 11:18 AM | #14 |
I wanna be Dave Join Date: Dec 2008 Location: anderson
there is a really easy mod to do on the rear axle the helps a ton an it is just drill out a hole an run a long screw all the way thew an it will help you out a ton on the rear grars cost less the .50 cents
03-31-2012, 11:46 AM | #15 | |
I'm running dual FX-R's right now in a 2.2 Bully, no where as good as dual CC Mamba Max's. Most are "picky details", but overall I prefer the CC ESC's & will be changing my Bully back to CC dual ESC's (not sure which ones yet). For the CC's: -Better drag brake -More worthwhile options for throttle/brake curves (you set, not some canned available settings) -Ability to program 1 ESC, save the profile then load into a 2nd ESC -CC link can be used to program CC BEC's Last edited by Charlie-III; 03-31-2012 at 11:49 AM. | |
03-31-2012, 11:52 AM | #16 |
all good on the castles but the size inless you get the mico pros i was going to do 2 bxrxls an then i weighed them an now not . ill be useing 2 fxrs cause i have one already or id do the micros |
03-31-2012, 06:33 PM | #17 | |
Pebble Pounder Join Date: Feb 2012 Location: wooster
Forums are about asking questions and having people help with mutual respect. Not shoving you to another thread because "one" guy said so... If searching was a rule, they would filter out ways to "repost" So...keep on keepin on... | |
04-01-2012, 04:01 AM | #18 |
thanks Ohio, no one said Harley was god, but it is a very comprehensive suggestion thread. perhaps you did not notice my suggestion to check out a few build threads also.
04-04-2012, 09:22 PM | #19 |
Quarry Creeper Join Date: Feb 2011 Location: A stupid town
RC4WD gears are always a good upgrade
06-04-2012, 12:38 AM | #20 |
I wanna be Dave Join Date: Oct 2007 Location: 801
| Re: Whats gonna break first? Easy simple fix....Chaotic Crawlers Titanium Steering Tierod Cllick Here to check it out |
Whats gonna break first? - Similar Threads | ||||
whats prone to break? | George014 | Axial SCX-10 | 16 | 12-02-2011 01:23 PM |
is neutral break the same as drag break? | rod-211 | Newbie General | 3 | 02-25-2011 08:33 PM |
whats gonna happen ?? | usa1man | Chit Chat | 1 | 02-09-2008 07:37 PM |
Whats it gonna be......?? | BigMark | Tires and Wheels | 3 | 10-01-2007 09:17 AM |
Wanted to break it in... Not break it! | Spoon | Tamiya TLT Crawlers | 8 | 08-30-2005 06:55 PM |
