07-23-2012, 07:01 PM | #1 |
Quarry Creeper Join Date: Apr 2012 Location: Talladega, AL
| Front end not pulling, well sometimes.
during this past weekends comp I noticed that my front end would not pull unless the rear pushed it enough to get it to roll a little. I could pick it up and put the front tires up against something and they would not turn, I could then push the front tires so they would turn a little and then they would start turning. My setup is dual sidewinder micro's that have been calibrated correctly, a set of one off 35 turn handwound Br00d motors, CCBEC, Futaba 4pks and a flysky rx until I get my Futaba 614ff back. I do not have another rx to try but I don't know if that would cause the problem or not. I'm going to swap the front and rear esc's at the rx to see if that changes anything when I get back to the rig tonight. Also nothing on the 4pks has changed since I swapped in the sidewinders after I burnt up the micro mamba pro's. Anyone have any idea's? I may can get some video of it tonight around 11pm central time if that would help.
07-23-2012, 07:24 PM | #2 |
I wanna be Dave Join Date: Jan 2008 Location: Arat Alabama
| Re: Front end not pulling, well sometimes.
Sounds to be a hanging brush or dirty comm.
07-23-2012, 07:30 PM | #3 |
Rock Crawler Join Date: Apr 2008 Location: Highlands Ranch, Co.
| Re: Front end not pulling, well sometimes. |
07-23-2012, 07:40 PM | #4 |
I wanna be Dave Join Date: Apr 2007 Location: Arlington, Washington
A. Hung Brush or Nasty comm B. Shorted Armature Rebuild the motors (comm cut, new brushes).....if problem stays, you shorted the armature. It happens, nasty binds can do bad stuff to even the best motors. Later EddieO |
07-23-2012, 08:05 PM | #5 |
O k. I'll turn the motors down on a lathe and put new brushes in it to see if that changes anything. These are the motors I asked EddieO and Tedrockz about about a 2 weeks ago. They were the "Crawler" motors. Sent from my DROID RAZR using Tapatalk 2 |
07-23-2012, 08:07 PM | #6 |
Rock Crawler Join Date: Sep 2009 Location: dartmouth ns
What kind of time are on your motors??
07-23-2012, 08:15 PM | #7 |
07-23-2012, 08:18 PM | #8 |
| Re: Front end not pulling, well sometimes. I think he is referring to run time. They are probably about due for a freshening.
07-23-2012, 08:28 PM | #9 |
RCC Addict Join Date: Oct 2008 Location: south caki laki again
True and considering the dead short that took out the two esc's and the receiver Last week it may have definitely shorted the armature!
07-23-2012, 09:21 PM | #10 | |
Sent from my DROID RAZR using Tapatalk 2 Last edited by irokcrawl; 07-23-2012 at 09:23 PM. | |
07-23-2012, 09:26 PM | #11 | |
Sent from my DROID RAZR using Tapatalk 2 | |
07-23-2012, 09:36 PM | #12 |
A new armature would be the fix for a dead arm. You can find a dead arm with a multimeter, no continuity between two or more segments of the comm. Try that before cutting them down, you will likely save yourself some time. If there is a dead segment, inspect it carefully for a visual break in the wire (if you care). Going back through my bins of dead arms I found that 100% of the open circuit arms had breaks at the termination point that weren't visible at first glance. I used to think it was an internal issue and I drove myself mad unwinding them trying to find it! You can find a shorted arm by testing continuity between the stator steel and the commutator. It is very rare, and a normal arm will not have continuity between the laminations and the comm. A third possible issue could be that you have contaminates in your comm segments causing a short. If the motor won't free spin with the brushes removed, clean out the comm gaps and try again. This is more frequent when high silver content brushes are used as it sticks a bit more than copper and graphite.
07-24-2012, 05:29 AM | #13 |
| Re: Front end not pulling, well sometimes. It created a dead short trough the entire system otherwise you would have only smoked 1 esc instead of both, by squeezing the throttle trying to make it move the brushes become welding rods to the armature creating burn spots. 11 volts to the armature and it not spinning may have created the short as jrh described at a connection point on the armature. Best to let Tedrockz (if he will) take them with him and go through them properly.
07-24-2012, 05:58 AM | #14 |
Quarry Creeper Join Date: Sep 2008 Location: Isle of Man
Sounds like one of the brushes has worn to the point the spring is resting on the end of the slot in the hood and not supplying pressure to the brush on the comm
07-24-2012, 06:03 AM | #15 | |
| Re: Front end not pulling, well sometimes. Quote:
In the long run it may be just easier to send them both to Eddie(og builder of it) or John. If you have to re-armature them both they are still worth the $. KRs are hard to come by. | |
07-24-2012, 06:28 AM | #16 |
Thats the nice thing about a rebuildable motor, you can keep them running for years and years with an arm and brush change. As long as they don't get beat on the rocks too hard!
07-24-2012, 07:59 AM | #17 |
true, pull them out and put the jrh's back in, I will meet up and take them to Ted Sunday and we can go from there.. |
07-24-2012, 08:39 AM | #18 | |
07-24-2012, 09:23 AM | #19 |
Rock Crawler Join Date: Oct 2010 Location: triad
i posted this in another thread like this when i had the same type of issue. i found out that my pinion gear set screw had come loose. The pinion gear was spinning on the shaft when a lot of bind was on it. Tightened up the set screw and it's all good.
07-24-2012, 09:34 AM | #20 | |
Front end not pulling, well sometimes. - Similar Threads | ||||
front end | norcaljeep | General Crawlers | 2 | 05-19-2006 03:54 PM |
Front end not pulling, possible belt problem | robert97dodge | General Crawlers | 6 | 09-14-2005 05:59 PM |
